trans cooler fitting size?
#98403
08/02/08 01:45 AM
08/02/08 01:45 AM
Posts: 363 San Diego
64dartsb
San Diego
could anyone tell me off hang the size and degree of the fittings that go to the trans cooler on a 904 trans. I think it's a 37 degree right? I'm going to go to the hardware store and get some new ones mine are crimped and it's not letting my trans cool.
thanks a lot
-matt
if your dreaming of your car then it's your dream car....
Re: trans cooler fitting size?
[Re: 64dartsb]
#98404
08/02/08 04:13 AM
08/02/08 04:13 AM
Posts: 25,796 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The case is threaded 1/8"-27 NPT and the factory cooler lines are 5/16" flare. The angle of the flare is 45°, the 37° flare is used on AN fittings.
[Re: John_Kunkel]
#98405
08/02/08 06:58 AM
08/02/08 06:58 AM
Posts: 1,771 St.Clair Shores MI.
tilt
St.Clair Shores MI.
45* = hardware store 37* = an or jic
68 CORONET R/T BEST MACHINE BUILT EFI'd TWIN TURBO(UP and RUNNING !!)
03 Mach1
[Re: 64dartsb]
#98407
08/04/08 08:46 PM
08/04/08 08:46 PM
64dartsb
San Diego
What's the best thing to replace those with and where can I find it? I was just going to get a barbed fititng for the hoses I have on there now but I'd prefer hard lines of course. I have tubing benders what should I ask for if I want that. I can flare it with my brake line flare tool I think. Do you think the hardware store would have this stuff? should I just use brake lines for the trans cooler lines or is there something better like fuel lines?
[Re: 64dartsb]
#98408
08/04/08 08:53 PM
08/04/08 08:53 PM
Challenger 1
Cincinnati, Ohio
Steel brake lines are best. You won't find any of that kind of stuff at a hardware store. Get everything from a auto parts store.
