I hate organosol and my PPG guy .. #98360
08/01/08 09:33 PM
08/01/08 09:33 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Third whack at using ppgs ( omnicrap or whatever it is )
to try to get my airgrabber right ..
Tonite was my third try .. with a new batch ..
all the metallic crept up to the top after it dried .. It looks like someone sprinkled glitter over gloss black paint ..
What the H happened to all the Organosol posts on this site and why isnt one Archived in TEch ????
Re: I hate organosol and my PPG guy .. [Re: sogtx] #98361
08/01/08 10:36 PM
08/01/08 10:36 PM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
I didn't know that there's a formula for Organasol in Omni.I wouldn't use it anyway.
Use DCC9355 if you want it to look good.
NMCA NSS 67 Coronet
Re: I hate organosol and my PPG guy .. [Re: Barry70GTX] #98362
08/01/08 11:08 PM
08/01/08 11:08 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Re: I hate organosol and my PPG guy .. [Re: Neil] #98363
08/01/08 11:11 PM
08/01/08 11:11 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
I used Gibson's stuff no issues.
Careful, your character's showing!
Re: I hate organosol and my PPG guy .. [Re: mopar346] #98364
08/02/08 12:04 AM
08/02/08 12:04 AM
new york
badsixpack Offline
badsixpack  Offline
new york
no issues,but it's a little to rough for me.
Re: I hate organosol and my PPG guy .. [Re: badsixpack] #98365
08/02/08 12:28 AM
08/02/08 12:28 AM
California
sixpaktoogo Offline
sixpaktoogo  Offline
California
And it's Lacquer! I wouldn't want to take the risk of spraying it over fresh enamel or urethane.
Re: I hate organosol and my PPG guy .. [Re: mopar346] #98366
08/02/08 12:42 AM
08/02/08 12:42 AM
+1
Re: I hate organosol and my PPG guy .. [Re: Neil] #98367
08/02/08 06:53 AM
08/02/08 06:53 AM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
https://board.moparts.org/ubbthreads/show...part=1&vc=1
wow thanks - i moparts googled it and it wouldnt show up for the life of me and i did spell it right ,,
Is Resto Ricks stuff OK ??
is it also a laquer ??
Re: I hate organosol and my PPG guy .. [Re: sogtx] #98368
08/02/08 07:08 AM
08/02/08 07:08 AM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
that tsb is cool but there have been posts that decsribed what the best gun to use , air pressure , best product ,
Am I the only one having a hard time spraying this stuff without zebra stripes ??
Re: I hate organosol and my PPG guy .. [Re: sogtx] #98369
08/02/08 08:07 AM
08/02/08 08:07 AM
WI
RestoRick Offline
RestoRick  Offline
WI
Hey Andy,
What exactly are you spraying? (lacquer or urethane)
paint # would help too...
Rick
Re: I hate organosol and my PPG guy .. [Re: RestoRick] #98370
08/03/08 10:35 PM
08/03/08 10:35 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
thanks for the quick reply ,, i was a contortionist trying to install a headliner in the car with a roll bar all weekend . stayed off the computer
The paint Im using is actually Concept 9355
I believe its a urethane .. .. My paint guy said all the texture went to the bottom of the can ..
I shook , I stirred it , I rolled it . I give up
Do you sell an amatuer painters friendly organisol ??
if you do have a product ,, can i paint over the urethane ??
Re: I hate organosol and my PPG guy .. [Re: sogtx] #98371
08/04/08 11:58 AM
08/04/08 11:58 AM
WI
RestoRick Offline
RestoRick  Offline
WI
Yes.. this machine is a time bandit...
I don't have a paint I'm ready to market at this point.
Here's what I'd suggest...
wet sand what you've done so far, to a flat surface without cutting through to a lighter color (if you have a lighter primer underneath).
500# would be good.
Let it dry thoroughly, then prep wipe.
Tack rag wipe it off nice & clean.
Take a deep breath and repeat your favorite mantra...
Now go over it with one medium wet coat, being careful to be "robotically consistent" with gun distant, speed and overlap.
With that clean flat and solid black base, you should be able to do this one clean coat with excellent results. Piling coat over coat can give trouble with the texture and zebra striping because you keep adding more texture with each coat.
If you did "work off the top" of the can and left texture on the bottom of the can, I also suggest getting a new can'o paint... otherwise you're going to be working with too much texture.
HTH,
Rick
Re: I hate organosol and my PPG guy .. [Re: sogtx] #98372
08/04/08 11:26 PM
08/04/08 11:26 PM
California
sixpaktoogo Offline
sixpaktoogo  Offline
California
Spraying Organosol is a major pain! I would suggest putting some ball bearings in the cup to agitate the mix between coats. The texture does settle rapidly, and can dry to the inside of the cup as well, causing possible chunks when you spray a second coat. I have actually emptied, flushed, and refilled my gun in between coats.
Re: I hate organosol and my PPG guy .. [Re: sixpaktoogo] #98373
08/05/08 10:54 PM
08/05/08 10:54 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
i had six marbles in my sprayer ..
I wonder how the factory did it or if teh paint was different materials, I hate to say it but Ive sprayed totally autos org in a can , and its not half bad .. but its not perfect ..
Re: I hate organosol and my PPG guy .. [Re: sogtx] #98374
08/16/08 10:27 AM
08/16/08 10:27 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
I have a new can of DCC9355 and nos DDL9355.
I did a comparison.
There is no visible texture additive in the DCC9355 but there is in real DDL9355 Organisol.
Can anyone list the formulas?
Re: I hate organosol and my PPG guy .. [Re: ThermoQuad] #98375
08/16/08 08:24 PM
08/16/08 08:24 PM
Wendy, I'm home.
dstryr Offline
dstryr  Offline
Wendy, I'm home.
Third post down by member beepbeep in this thread has the DDL9355 formula, as follows:
DMA349 Coarse Poly 24.0
DMA358 Strong Black 804.0
DMA364 Texture 972.0
Here is another good thread on organosol as well.
BTW, is one of them a metallic compound? My hood has a metallic sheen to it when the sun hits it just right.
dstryr, since 1986.
Re: I hate organosol and my PPG guy .. [Re: dstryr] #98376
08/29/08 07:48 AM
08/29/08 07:48 AM
ThermoQuad Offline
ThermoQuad  Offline
DCC9355 IS NOT the same as DDL9355...not even close
I just sprayed some DCC9355...
For the real deal in organisol paint DDL9355 must be used. As to the whether or not the correct texture additive is in the new DDL9355-that is unknown at this point as any correct technical info seems to be made of unobtainium.
Re: I hate organosol and my PPG guy .. [Re: ThermoQuad] #98377
08/29/08 03:37 PM
08/29/08 03:37 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
This is what mine was broken down.
