I hate organosol and my PPG guy ..
#98360
08/01/08 09:33 PM
08/01/08 09:33 PM
Posts: 5,180 upstate western ny
sogtx
upstate western ny
Third whack at using ppgs ( omnicrap or whatever it is ) to try to get my airgrabber right .. Tonite was my third try .. with a new batch .. all the metallic crept up to the top after it dried .. It looks like someone sprinkled glitter over gloss black paint .. What the H happened to all the Organosol posts on this site and why isnt one Archived in TEch ????
Re: I hate organosol and my PPG guy ..
[Re: Neil]
#98363
08/01/08 11:11 PM
08/01/08 11:11 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
I used Gibson's stuff no issues.
Careful, your character's showing!
[Re: mopar346]
#98366
08/02/08 12:42 AM
08/02/08 12:42 AM
+1
[Re: sogtx]
#98369
08/02/08 08:07 AM
08/02/08 08:07 AM
Posts: 2,304 WI
RestoRick
WI
Hey Andy, What exactly are you spraying? (lacquer or urethane) paint # would help too... Rick
[Re: RestoRick]
#98370
08/03/08 10:35 PM
08/03/08 10:35 PM
sogtx
upstate western ny
thanks for the quick reply ,, i was a contortionist trying to install a headliner in the car with a roll bar all weekend . stayed off the computer
The paint Im using is actually Concept 9355
I believe its a urethane .. .. My paint guy said all the texture went to the bottom of the can ..
I shook , I stirred it , I rolled it . I give up
Do you sell an amatuer painters friendly organisol ??
if you do have a product ,, can i paint over the urethane ??
[Re: sogtx]
#98371
08/04/08 11:58 AM
08/04/08 11:58 AM
Posts: 2,304 WI
RestoRick
WI
Yes.. this machine is a time bandit... I don't have a paint I'm ready to market at this point. Here's what I'd suggest... wet sand what you've done so far, to a flat surface without cutting through to a lighter color (if you have a lighter primer underneath). 500# would be good. Let it dry thoroughly, then prep wipe. Tack rag wipe it off nice & clean. Take a deep breath and repeat your favorite mantra... Now go over it with one medium wet coat, being careful to be "robotically consistent" with gun distant, speed and overlap. With that clean flat and solid black base, you should be able to do this one clean coat with excellent results. Piling coat over coat can give trouble with the texture and zebra striping because you keep adding more texture with each coat. If you did "work off the top" of the can and left texture on the bottom of the can, I also suggest getting a new can'o paint... otherwise you're going to be working with too much texture. HTH, Rick
[Re: sogtx]
#98372
08/04/08 11:26 PM
08/04/08 11:26 PM
Posts: 636 California
sixpaktoogo
California
Spraying Organosol is a major pain! I would suggest putting some ball bearings in the cup to agitate the mix between coats. The texture does settle rapidly, and can dry to the inside of the cup as well, causing possible chunks when you spray a second coat. I have actually emptied, flushed, and refilled my gun in between coats.
