1971 CUDA GRILLE #98338
08/01/08 08:48 PM
08/01/08 08:48 PM
SoCal
F6 DAYTONA Offline OP
SoCal
DO THEY STILL REPO THIS? HOW IS THE QUALITY? ANYBODY USE THESE YET? INPUT...PLEASE
Re: 1971 CUDA GRILLE [Re: F6 DAYTONA] #98339
08/01/08 09:15 PM
08/01/08 09:15 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I don't know if they are still being offered or not, as far as quality. They were cast resin, (not injection molded plastic like originals, BIG difference in raw material properties!) cast Urethane resin is not the best material for anything on the exterior of a car (cast Urethane resin does not like heat, warps, sags, etc.) and they are slightly dimensionally smaller than originals as wll due to material shrink in the casting process. They also come without any of the unique and expensive stainless steel trim (which is really one of the biggest problems). So, for around $500.00 they are better than nothing but don't expect one to approach the quality of an original.
Re: 1971 CUDA GRILLE [Re: ScottSmith_Harms] #98340
08/02/08 02:13 AM
08/02/08 02:13 AM
SoCal
SoCal
thanks for the input...
Re: 1971 CUDA GRILLE [Re: F6 DAYTONA] #98341
08/02/08 03:25 AM
08/02/08 03:25 AM
Arkansas
hotrod98 Offline
hotrod98  Offline
Arkansas
If enough people decide that they're interested, we might be able to convince Mike at BEA parts to pursue making an injection molded 71 Cuda grille that would be correct in every respect. I already told him that I want the first one if he builds them. His 70 Grille assembly is truly outstanding in every respect.
1970 Superbird 4-speed, Dana, bucket seats
Re: 1971 CUDA GRILLE [Re: hotrod98] #98342
08/04/08 02:34 AM
08/04/08 02:34 AM
SoCal
SoCal
I WOULD BE SECOND RIGHT BEHIND YOU...OR A RESTORED GRILLE FOR $2,500.00
