Speedo Cable #983313
04/30/11 06:39 PM
04/30/11 06:39 PM
Under My Car
Mopar_Country Offline OP
Under My Car
Just put a new speedo cable on the Dart and took it for a ride. Got back and parked it in the garage and shut it off, looked down and I'm still doing 55 .
What I am wondering has anyone else had this happen, do they take a few miles to "loosen" up?
I pulled the cable out and lubed it before install and it has no sharp bends or turns.
Re: Speedo Cable [Re: Mopar_Country] #983314
04/30/11 07:36 PM
04/30/11 07:36 PM
no, Was the speedo Ok b 4 & there was a cable prob, noise or needle jumping (from sticking/releasing cable)
Re: Speedo Cable [Re: RapidRobert] #983315
04/30/11 09:24 PM
04/30/11 09:24 PM
Under My Car
Under My Car
It worked fine before, Ive just been changing things out and upgrading parts. It still works it just sticks now. It does return to normal after a couple of minutes. I guess I double check the cable and make sure it doesn't have a tight bend somewhere.
Re: Speedo Cable [Re: Mopar_Country] #983316
04/30/11 09:45 PM
04/30/11 09:45 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
You can remove the end from the trans and put it in a drill. You will have to spin it COUNTERclockwise to get the speedo to read. This may help isolate the problem. I would tend to think that the speedometer itself is to blame. How ELSE could the needle stick at 55 mph? The cable stops spinning when the car stops, right?
Re: Speedo Cable [Re: Kern Dog] #983317
04/30/11 11:27 PM
04/30/11 11:27 PM
Under My Car
Under My Car
Well it didn't do it until I changed the speedo pinion and cable. I made the change because I upgraded to an 8 3/4 rear with different gears and needed the new pinion, so I figured why not change the cable, the clip that held the cable to the back of the speedo was cracked and starting to break I'll have to check and make sure I got it on the back the way it should be I guess. I will try the drill tomorrow and see if I can isolate it.
It did not hang up previous to the change, that's what has me confused.
Re: Speedo Cable [Re: RapidRobert] #983318
04/30/11 11:30 PM
04/30/11 11:30 PM
Under My Car
Under My Car
No jumping, no noise, but it did seem to read a little lower than what it should.
Re: Speedo Cable [Re: Mopar_Country] #983319
04/30/11 11:31 PM
04/30/11 11:31 PM
Poplar Bluff, Mo. 63901
2
268RTs4ME Offline
268RTs4ME  Offline
Did you lube the new cable??
Re: Speedo Cable [Re: 268RTs4ME] #983320
04/30/11 11:33 PM
04/30/11 11:33 PM
Under My Car
Under My Car
Yes, I pulled it out and used the lube supplied from one end to the other.
Re: Speedo Cable [Re: Mopar_Country] #983321
05/01/11 12:39 AM
05/01/11 12:39 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Well the cable is just a mechanical rotational transfer device. Hence car stops cable stops. If the head is hanging up and showing mph then the problem is in the head.
Re: Speedo Cable [Re: NITROUSN] #983322
05/01/11 12:57 AM
05/01/11 12:57 AM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
My Road Runner did that after I reasembled it. If I hit 55 the speedo stuck there. Tap it with my finger and it would drop back to zero. The problem was in the speedo head.
Re: Speedo Cable [Re: Mopar_Country] #983323
05/01/11 11:11 AM
05/01/11 11:11 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Although very unlikely but , Make sure the cable isn't binding where it enters at the backside of speedometer head. If it's ok, you have internal speedometer issues.
