Speedo Cable
#983313
04/30/11 06:39 PM
04/30/11 06:39 PM
Posts: 1,216 Under My Car
Mopar_Country
Under My Car
Just put a new speedo cable on the Dart and took it for a ride. Got back and parked it in the garage and shut it off, looked down and I'm still doing 55 . What I am wondering has anyone else had this happen, do they take a few miles to "loosen" up? I pulled the cable out and lubed it before install and it has no sharp bends or turns.
Re: Speedo Cable
[Re: RapidRobert]
#983318
04/30/11 11:30 PM
04/30/11 11:30 PM
Mopar_Country
Under My Car
no, Was the speedo Ok b 4 & there was a cable prob, noise or needle jumping (from sticking/releasing cable)
No jumping, no noise, but it did seem to read a little lower than what it should.
Re: Speedo Cable
[Re: Mopar_Country]
#983321
05/01/11 12:39 AM
05/01/11 12:39 AM
Posts: 18,425 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Well the cable is just a mechanical rotational transfer device. Hence car stops cable stops. If the head is hanging up and showing mph then the problem is in the head.
