Challenger #982976
04/30/11 07:26 AM
04/30/11 07:26 AM
New Jersey
FC7 cuda Offline OP
FC7 cuda  Offline OP
New Jersey
Has anybody ever see a FY1 challenger with a V9Y transverse stripe? Any pictures out there?
Re: Challenger [Re: FC7 cuda] #982977
04/30/11 01:23 PM
04/30/11 01:23 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I have not seen one - yet. Have you found one?
Both colors would be banana, so all you would see are the masking tape lines.
A white Challenger with a white bee stripe exists, so does a purple one with a purple stripe.
Re: Challenger [Re: Alaskan_TA] #982978
05/01/11 07:28 AM
05/01/11 07:28 AM
New Jersey
FC7 cuda Offline OP
FC7 cuda  Offline OP
New Jersey
Does that increase the value?
Re: Challenger [Re: FC7 cuda] #982979
05/01/11 11:42 AM
05/01/11 11:42 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Maybe to some? It would be a real oddity & odd cars do have their own following for sure.
Is it still in original paint? The others I have seen with the same body paint / stripe color have all been repainted in the past. I would love to see an original example. Any photos or data on the car you can share?
Re: Challenger [Re: Alaskan_TA] #982980
05/01/11 12:31 PM
05/01/11 12:31 PM
Jamestown, Indiana
James74 Offline
James74  Offline
Jamestown, Indiana
slightly off topic, and nothing personal against the OP, but when did Mopar guys start using codes to describe things? I seem to see it more and more, and I have no idea what the questions are......
Re: Challenger [Re: Alaskan_TA] #982981
05/02/11 01:44 PM
05/02/11 01:44 PM
Farmington, CT
KISSAlien Offline
KISSAlien  Offline
Farmington, CT
Not all of them.
Re: Challenger [Re: James74] #982982
05/02/11 01:50 PM
05/02/11 01:50 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Well then either learn the codes or ignore the post.... Codes have been used since at least the early sixties...If theres a coded tag the plant was using codes....Just more people use them now...And have for a long time....
Re: Challenger [Re: Alaskan_TA] #982983
05/02/11 01:57 PM
05/02/11 01:57 PM
Farmington, CT
KISSAlien Offline
KISSAlien  Offline
Farmington, CT
I have records for the following same stripe combos in my records:
EW1/V9W - White
FC7/V9C - Plum Crazy
EK2/V9K - Go Mango
FF4/V9F - Green
I know Galen also has Black and Banana cars in his records, but I don't have the info for them.
Re: Challenger [Re: James74] #982984
05/02/11 02:18 PM
05/02/11 02:18 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Silly question in the A12 forum
Re: Challenger [Re: Morty426] #982985
05/02/11 03:04 PM
05/02/11 03:04 PM
Farmington, CT
KISSAlien Offline
KISSAlien  Offline
Farmington, CT
Nobody is sure why these cars came about. Some think it was someone at the dealership not knowing how to code stripe delete. Others think it might be because all other bumble stripes were tape stripes and that's what they were expecting to get with the Challenger.
Most of these cars have relatively early build dates, which would support either option. My car is the only one I know of with a later build date.
Go-Mango car - 817
Green car - 924
Black car - B08
Purple car - B15
White car - 508
Re: Challenger [Re: KISSAlien] #982986
05/02/11 03:24 PM
05/02/11 03:24 PM
cataclysm80 Offline
cataclysm80  Offline
I thought there was a black/black car mentioned here on moparts a while back, but the guy never came up with pictures.
Has an original paint car finaly been found?
Are we sure that the colors were really exactly the same, and that the stripe color wasn't slightly different?
Does this mean you're going to fix that Challenger now Ken?
Tav
Re: Challenger [Re: cataclysm80] #982987
05/02/11 03:36 PM
05/02/11 03:36 PM
Farmington, CT
KISSAlien Offline
KISSAlien  Offline
Farmington, CT
There was a black/black car on eBay with a fake tag. Not sure if that's the one that you mean.
Not that I know of. I'm pretty sure the paint on mine is original, but not so much the stripe (though it is old). It's over the body paint and is lacquer, not enamel. Could have been done at any time in it's life. Not sure when the black engine compartment and rear panel were done either.
We're not sure of anything. The stripe list does call the stripes Go-Mango, Banana, and Plum Crazy though, for example. The paint code for black pinstripes differs from TX9. The white pinstipe paint code is the same as EW1, but I've heard there is other documentation where it is different.
The pink one isn't quite done yet. Money is a lot tighter now than when I bought the white car 3 years ago, so I'm not sure I'll ever get that one done.
That's all I know now Tav.
Re: Challenger [Re: KISSAlien] #982988
05/02/11 03:38 PM
05/02/11 03:38 PM
Farmington, CT
KISSAlien Offline
KISSAlien  Offline
Farmington, CT
PS> I also can't really do that car until I figure out how it should be done.
Re: Challenger [Re: Alaskan_TA] #982989
05/02/11 03:41 PM
05/02/11 03:41 PM
Farmington, CT
KISSAlien Offline
KISSAlien  Offline
Farmington, CT
Barry, do you think they would have gone to all that trouble, as opposed to catching it before they painted the stripe and just not masking and painting it?
Re: Challenger [Re: KISSAlien] #982990
05/02/11 03:46 PM
05/02/11 03:46 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I would try using 800 grit & carefully sand away the lacquer... Sand the same direction as the stripe so you don't block the definition line between the white away.. I would intentionally try to stay away from the lines till you've gotten to the first paint job further back so you can watch close as the top paint is removed closer to the tape line...
Re: Challenger [Re: 1_WILD_RT] #982991
05/02/11 04:43 PM
05/02/11 04:43 PM
Farmington, CT
KISSAlien Offline
KISSAlien  Offline
Farmington, CT
We did that a few years ago when I brought the trunk lid to Carlisle. No help really.
I think it was Barry Washington, Dan Pausch, and Mike from Rocket Restorations.
Re: Challenger [Re: KISSAlien] #982992
05/02/11 09:52 PM
05/02/11 09:52 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Yep, I do. The folks masking the stripes most likey just did their job. After the stripe paint was sprayed & baked, the maskers would then do their job & send it for body paint. In some of these cases, the folks removing the masking materials likely had a good chuckle when they realized the paint colors were the same.
Hopefully some original same color examples show up someday so we know for sure though.
Re: Challenger [Re: Alaskan_TA] #982993
05/03/11 07:01 AM
05/03/11 07:01 AM
New Jersey
FC7 cuda Offline OP
FC7 cuda  Offline OP
New Jersey
So you are saying the stripe was painted first then masked and then the body was painted .....I thought the stripes were semi gloss
Re: Challenger [Re: FC7 cuda] #982994
05/03/11 09:56 AM
05/03/11 09:56 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Stripe was painted first then masked and then the body was painted...
Stripe was gloss same as body...
Re: Challenger [Re: 1_WILD_RT] #982995
05/03/11 10:50 AM
05/03/11 10:50 AM
New Jersey
FC7 cuda Offline OP
FC7 cuda  Offline OP
New Jersey
Why did they do it that way ? Are you sure on the gloss???
