Holley Accelerator Pump Hydrolock #982623
04/29/11 05:38 PM
04/29/11 05:38 PM
California
Hotlumpy Offline OP
Hotlumpy  Offline OP
California
I have a Holley 3310 750 that the accelerator pump keeps hydro-locking on me. I take the float bowl off and it will squirt when depressed, but locks up within a minute of running. I blew out the passage in the metering block, no problem. I couldn't seem to get air to pass through the passage on the main body of the carb, and I'm not sure what to do next.
Re: Holley Accelerator Pump Hydrolock [Re: Hotlumpy] #982624
04/29/11 05:53 PM
04/29/11 05:53 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
Make sure the bowl gasket is installed correctly (accl passage on the correct side), fooled me once!
jess
Yeah, it's hopped up to over 160...
Re: Holley Accelerator Pump Hydrolock [Re: jt4406] #982625
04/29/11 05:55 PM
04/29/11 05:55 PM
California
Hotlumpy Offline OP
Hotlumpy  Offline OP
California
Yeah, there is a slot on both sides of my gasket, car was running fine and just started this. I have replaced the gaskets and blown out the passage in the metering block, no help.
Re: Holley Accelerator Pump Hydrolock [Re: Hotlumpy] #982626
04/29/11 06:11 PM
04/29/11 06:11 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
did you blow out the passage in the main body? is the check needle below the squirter stuck?
Re: Holley Accelerator Pump Hydrolock [Re: dartman366] #982627
04/29/11 06:57 PM
04/29/11 06:57 PM
California
Hotlumpy Offline OP
Hotlumpy  Offline OP
California
Couldn't get air to go through the main body passage, how would I chesk the needle below the squirter? I'm pretty new at the insides of this carb.
Re: Holley Accelerator Pump Hydrolock [Re: Hotlumpy] #982628
04/29/11 07:05 PM
04/29/11 07:05 PM
Take out the big phillips screw and the squirter then turn it upside down to get the brass needle out and there is a gasket under the squirter
Re: Holley Accelerator Pump Hydrolock [Re: RapidRobert] #982629
04/29/11 07:40 PM
04/29/11 07:40 PM
California
Hotlumpy Offline OP
Hotlumpy  Offline OP
California
So now I have this needle out, then blow out the passages aqain & re-install?
Re: Holley Accelerator Pump Hydrolock [Re: Hotlumpy] #982630
04/29/11 11:50 PM
04/29/11 11:50 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
after taking the needle out then use carb cleaner and blow thru it and make sure it is clear then inspect the needle for damage or sign's of rust or corrosion, those needles weren't always brass some were steel, also make sure the holes in the squirter are clear, take a small wire slightly smaller that the holes and run the wire thru them to make sure there isn't any debris in them.
Re: Holley Accelerator Pump Hydrolock [Re: dartman366] #982631
04/30/11 01:23 PM
04/30/11 01:23 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Try it without the squirter nozzle and check valve in place.
Re: Holley Accelerator Pump Hydrolock [Re: Magnum] #982632
04/30/11 11:33 PM
04/30/11 11:33 PM
Rome, GA
GTXX Offline
GTXX  Offline
Rome, GA
if you do this, lay a rag in the carb to catch the check valve
Re: Holley Accelerator Pump Hydrolock [Re: GTXX] #982633
05/02/11 11:36 PM
05/02/11 11:36 PM
Magnum Offline
Magnum  Offline
Good catch (literally) GTXX. It was a typo. I meant without the check valve in place.
