valley pan,intake gasket question? #982578
04/29/11 05:23 PM
04/29/11 05:23 PM
weymouth,mass.
meepmeep70 Offline OP
weymouth,mass.
kinda dumb,but getting all my ducks in a row so to speak,changing from 4bbl to 6pk manifold,when ordering new felpro gaskets,i would want 2 pair,one i would think would go under valley pan,second on top? thanks
Re: valley pan,intake gasket question? [Re: meepmeep70] #982579
04/29/11 05:25 PM
04/29/11 05:25 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Why even bother with paper gaskets? They really aren't necessary. The tin is reusable a couple of times at least.
Re: valley pan,intake gasket question? [Re: stumpy] #982580
04/29/11 05:29 PM
04/29/11 05:29 PM
weymouth,mass.
weymouth,mass.
so i'm just wanting the intake gaskets to mount between the tin and manifold,right? just though there may have been a second gasket,similiar to oil pan,windage tray
Re: valley pan,intake gasket question? [Re: meepmeep70] #982581
04/29/11 05:37 PM
04/29/11 05:37 PM
weymouth,mass.
weymouth,mass.
so i'm just looking for a felpro valley pan gaskets,sealant between pan and manifold
Re: valley pan,intake gasket question? [Re: meepmeep70] #982582
04/29/11 05:42 PM
04/29/11 05:42 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You don't need paper gaskets at all. You just need a little RTV on the corners
Re: valley pan,intake gasket question? [Re: stumpy] #982583
04/29/11 05:47 PM
04/29/11 05:47 PM
weymouth,mass.
weymouth,mass.
alright,thank you,crossing it of my summit list ,thank you for helping
Re: valley pan,intake gasket question? [Re: meepmeep70] #982584
04/29/11 05:50 PM
04/29/11 05:50 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
If your heads have been milled or block decked you'll need at least one set of paper. I had to use one paper set on the old set-up.
Coming soon!!!!
Re: valley pan,intake gasket question? [Re: Mr.Yuck] #982585
04/29/11 05:56 PM
04/29/11 05:56 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
That depends on whether or not the intake has been milled to match.
Re: valley pan,intake gasket question? [Re: Mr.Yuck] #982586
04/29/11 05:57 PM
04/29/11 05:57 PM
weymouth,mass.
weymouth,mass.
thank you mr yuck,i will order a set so i have them
Re: valley pan,intake gasket question? [Re: meepmeep70] #982587
04/29/11 06:18 PM
04/29/11 06:18 PM
scratchnfotraction Offline
most times not needed,I do use the VP that has the heat cross over blocked with the alum intake and carb to keep the heat soak down.
rtv in the corners and across the end rails lightly.
the good part is,it is reusable a couple of times for fast intake/carb swaps.
some times the gaskets can be to thick,so check with member 'topside", he sells some thinner gaskets sets that are cheap and good quality.
member "road hazzard" has a nice brand of gaskets that he makes as well,great non-stick gasket compound,IIRC
congrats on your new 6-pak set up!
you will need tires soon
Re: valley pan,intake gasket question? [Re: scratchnfotraction] #982588
04/29/11 06:29 PM
04/29/11 06:29 PM
weymouth,mass.
weymouth,mass.
thanks Scratchin,yep,ordered tires with my summit order
Re: valley pan,intake gasket question? [Re: scratchnfotraction] #982589
04/29/11 06:31 PM
04/29/11 06:31 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
IF you take your time with the VP and install the intake with care ... you will NEVER have to buy another VP ...ever again.
That is IF you "glue" the papers onto the VP ...and then "Pam" the intake man and head surface. It will seal great and come apart smoothly.
The engineers at Mopar and Felpro came-up with those "papers" for a reason.
Re: valley pan,intake gasket question? [Re: dOrk !] #982590
04/29/11 06:32 PM
04/29/11 06:32 PM
weymouth,mass.
weymouth,mass.
,thank you doc
Re: valley pan,intake gasket question? [Re: meepmeep70] #982591
04/29/11 07:03 PM
04/29/11 07:03 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Sorry Doc but the engineers at Mopar didn't have a thing to do with the paper gaskets. That was a felpro idea to make up for head height changes. I have bought a boatload of valley pans including felpro over the years that never came with paper gaskets.
Re: valley pan,intake gasket question? [Re: stumpy] #982592
04/29/11 07:10 PM
04/29/11 07:10 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
That is not what I heard stumpy ..... it was due to alignment probs with the alum Eddy intake is the reason for the papers.
Doing the papers can be a PITA .... but it is worth-it.
Re: valley pan,intake gasket question? [Re: dOrk !] #982593
04/29/11 07:15 PM
04/29/11 07:15 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Again Doc sorry but that is a nice story not reality.
Re: valley pan,intake gasket question? [Re: stumpy] #982594
04/29/11 07:18 PM
04/29/11 07:18 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
....if that is not reality ... then why isn't there a VP and paper-kit for the B engine also ?
Re: valley pan,intake gasket question? [Re: dOrk !] #982595
04/29/11 07:29 PM
04/29/11 07:29 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I can't answer that but as a line mecahnic for Mopar in the 60s and 70s I do know it wasn't a Chrysler deal.
Re: valley pan,intake gasket question? [Re: stumpy] #982596
04/29/11 07:36 PM
04/29/11 07:36 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
I was never a line-mech ...what I know about that is from the guys at Highland Park and CTC.
And from what I know .. there were more std OEM alignment issues with the B-engine. The block deck-heights with the B-engine are famous for being way-off in left-field.
Re: valley pan,intake gasket question? [Re: stumpy] #982597
04/29/11 07:47 PM
04/29/11 07:47 PM
Sobieski Wi
bee1971 Online work
bee1971  Online Work
Sobieski Wi
This subject gets beat to death
Doo a search , its been discussed a million times
However its funny how some say the paper gaskets are never needed
Really , that brand new Holley Street Dominator Intake that i installed about ten years ago almost cost me a motor - It was sucking oil so bad on the passenger side head intake ports because i failed to use the paper gaskets at all
However the Edelbrock Intakes that i installed didnt require the paper gaskets
If i was buying any intake , used , brand new , aluminum blah blah blah , i would let the intake dictate on whether i would bee using paper gaskets or not by test fitting , lining up the bolt holes etc.
Peace Scott
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
