Re: 727 Overheats!
[Re: coronet1966d]
#982436
04/29/11 09:28 AM
04/29/11 09:28 AM
RapidRobert
Hi Randy, not from overheating but from front pump seal needs R&R
Re: 727 Overheats!
[Re: coronet1966d]
#982438
04/29/11 09:44 AM
04/29/11 09:44 AM
Posts: 15,552 Norwich CT USA
moparts
Norwich CT USA
Over heating ?
Coming out the vent right above the seal?
The one time I overheated a trans it was coming out the filler tube also.
You sure that the trans was not just over full and fluid was expanding and coming out the vent
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
Re: 727 Overheats!
[Re: coronet1966d]
#982441
04/29/11 10:50 AM
04/29/11 10:50 AM
Posts: 75,089 A Banana Republic near you.
JohnRR
its not slipping, it not shooting out of the dipstick either. i have a cheetah reverse manual VB and a mancinis 3200 stall converter
Then you either have a blockage in the cooler circuit or it's overfilled which will cause the fluid to foam and come out the vent which may APPEAR to be the front seal.
Do you have a temp gauge and where is it installed ?
Re: 727 Overheats!
[Re: coronet1966d]
#982443
04/29/11 11:12 AM
04/29/11 11:12 AM
JohnRR
its not overfilled either, this wasnt a small amount of fluid that came out. i could follow a trail a couple miles of fluid that dumped out. i lost 6 quarts total. the trans cooler is new, radiator is new and the trans lines are stainless steel pre bent and also new
Again , TEMP GAUGE location ???
sounds like a seal that was installed DRY and/or was damaged on install.
Re: 727 Overheats!
[Re: coronet1966d]
#982445
04/29/11 11:58 AM
04/29/11 11:58 AM
Posts: 849 Avondale AZ
Prodart440
Avondale AZ
Just because the radiator is new does not mean the cooler in it isn't plugged. I would check cooler flow.
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
Re: 727 Overheats!
[Re: 68dodge]
#982451
04/29/11 12:52 PM
04/29/11 12:52 PM
Posts: 2,682 Clinton Twp. Michigan
coronet1966d
One thing I would do, is not run the trans fluid into the radiator cooler. I would only use the external transmission cooler.
when i installed the cooler i considered this, whats the best way to do it? ive heard arguments for both ways
Re: 727 Overheats!
[Re: modelmakerinc]
#982453
04/29/11 03:26 PM
04/29/11 03:26 PM
JohnRR
Coronet1966d
I finally spoke with a trans guy and explained to me that with a Cheetah Reverse Valve body somehow it spins the drum over what would be considered normal and foams the fluid until it pukes out.
Henry
I'm not going to debate this one but from what I know of the internals of the 727 and how things are connected this is impossible , the drum is connected mechanically to the sun shell which is geared to the rear planet which is splined to the mainshaft and there is no way I can see for it to spin faster with a different valve body configuration.
That said, I missed the REVERSE manual VB part and this is a quote from CRT's tech page ...
On 727s & 904s with Trans Brake or reverse pattern valve bodies, CRT recommends that you relocate the vent to the rear of the case. The stock vent is in the pump cover, fluid will leak out of the stock vent when using a trans brake. Drill the stock vent hole with a 11/23 drill bit, then tap the hole using a 1/8 pipe tap. Install 1/8 pipe plug. drill hole at the 11 O clock piston in the rear of case as shown in picture above and install new vent. Also block off the feed hole in the park gear, or you will have fluid spitting out the vent. See pic below
