6.1 Hemi short oil filter #981306
04/27/11 03:15 AM
04/27/11 03:15 AM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline OP
I'm installing a 6.1 Hemi in an E-body. I got the engine in. I used the 45 degree adapter for the oil filter. The stock length oil filter still won't quite fit as it would interfere with the K-member. Are there any filters that are a little shorter? Brand and part number would be great. Thanks in advance.
Re: 6.1 Hemi short oil filter [Re: Barnabas_Kriss] #981307
04/27/11 04:39 PM
04/27/11 04:39 PM
dbogie Offline
dbogie  Offline
I pull the rh motor mount bolt and use the engine picker to tilt the block.does not take much.
Re: 6.1 Hemi short oil filter [Re: dbogie] #981308
04/28/11 03:08 AM
04/28/11 03:08 AM
808CUDA Offline
808CUDA  Offline
AC DELCO PF-13
Read this post I made some years ago when you have the time:
https://board.moparts.org/ubbthreads/show...e=1#Post3930520
Re: 6.1 Hemi short oil filter [Re: 808CUDA] #981309
04/28/11 01:47 PM
04/28/11 01:47 PM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
Or.......Grab a cut-off wheel and a welder to make a notch in the K-frame......
Blown71X V2.0 under construction 71 Cuda 383 4-SPD (maybe for sale) 2010 Challenger B5 Classic
Re: 6.1 Hemi short oil filter [Re: Blown71X] #981310
04/29/11 03:09 AM
04/29/11 03:09 AM
Too late to notch the K-frame. K-frame has been powder coated and engine already installed.
808CUDA - I did read your post several times, it has been very helpful.
I have one more question for you:
I used the same TTI mounts with the stock rubber insulators. The engine seems to sit at a slight angle (the front is a little higher than the rear). The headers clear everything fine, it just looks odd. I already spaced the rear trans mount up, but still a little tilted. I still need to check my driveline angles. Did you encounter anything like this with your swap? (I'm installig a Keisler/Tremec 5-speed).
Re: 6.1 Hemi short oil filter [Re: Barnabas_Kriss] #981311
04/30/11 04:33 AM
04/30/11 04:33 AM
808CUDA Offline
808CUDA  Offline
Honestly I never noticed an alignment issue and the engine appeared level to me. I sold the car a few years ago and I can't take another look.
