528 Hemi With Mopar Dual Plane - Exhaust Heat?????? #980941
04/26/11 11:10 AM
04/26/11 11:10 AM
Detroit, MI
kz5rt2 Offline OP
kz5rt2  Offline OP
Detroit, MI
Hello all,
I bought a crate Hemi and am using a single four dual plane intake. I see it has the original exhaust heat ports on the manifold (reference the photo).
Since I'm using TTI headers and not the original cast iron exhaust manifolds, what should I do with these exhaust holes?
Any suggestions are appreciated.
Re: 528 Hemi With Mopar Dual Plane - Exhaust Heat?????? [Re: kz5rt2] #980942
04/26/11 12:02 PM
04/26/11 12:02 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Just make some plates up from scrap steel to seal them up or just leave them open. I would send that manifold for scrap myself but maybe you need to use it for hood clearance issues?
Sheldon
Re: 528 Hemi With Mopar Dual Plane - Exhaust Heat?????? [Re: RUNCHARGER] #980943
04/26/11 01:01 PM
04/26/11 01:01 PM
Detroit, MI
kz5rt2 Offline OP
kz5rt2  Offline OP
Detroit, MI
Is this intake manifold wrong for the application?
Re: 528 Hemi With Mopar Dual Plane - Exhaust Heat?????? [Re: kz5rt2] #980944
04/26/11 02:44 PM
04/26/11 02:44 PM
Central Ky, area
CHRYCOFAN Offline
CHRYCOFAN  Offline
Central Ky, area
I just did like said & made plates for them...
And Yes, I needed the hood clearance the intake gives.
Butch
Re: 528 Hemi With Mopar Dual Plane - Exhaust Heat?????? [Re: kz5rt2] #980945
04/26/11 05:10 PM
04/26/11 05:10 PM
RUNCHARGER Offline
RUNCHARGER  Offline
The manifold probably leaves at least 50HP on the table compared to a Barton or Indy manifold. However usually hood clearance is a problem with a stock type car.
Sheldon
Re: 528 Hemi With Mopar Dual Plane - Exhaust Heat?????? [Re: kz5rt2] #980946
04/26/11 05:45 PM
04/26/11 05:45 PM
desomod Offline
desomod  Offline
You can just keep those openings uncovered. They were to circulate hot exhaust gas to heat the carb on a stock setup.
Have you thought about the Stage V dual quad intake? It is a single plane design but appears to have the correct height. I am running it on a 528" Hemi Cuda, shaker hood and it looks stock.
Re: 528 Hemi With Mopar Dual Plane - Exhaust Heat?????? [Re: desomod] #980947
04/26/11 06:27 PM
04/26/11 06:27 PM
Detroit, MI
kz5rt2 Offline OP
kz5rt2  Offline OP
Detroit, MI
I had the engine dyno'd with the single carb setup because I am going to put a 426 street wedge air cleaner on. Yes, I had to go with the dual plane for hood clearance as well.
Gary Stanton built the 528. I picked up another 25 ftlb of torque with this setup but lost about 18hp he said. Not that I needed the extra torque of 640 ftlbs, this should be a blast on the street and can't wait! Gotta love those Hemis
