Re: Head gasket........
[Re: WannaRunner]
#980829
04/26/11 02:00 PM
04/26/11 02:00 PM
Posts: 4,799 ILL
MLR426
ILL
I have a stock 383, Is a EX268 cam a trouble free upgrade? what would be the thinnest head gasket I could use to bring up the compression after installing this cam? without of course smacking the valves.......
compression ? John ask the question what pistons? I assume you have stock pistons with stock compression height, the valves wouldn't even be close to hitting with that cam. If you want more compression cut the heads. 20 steel head shim with copper coat. The trouble free part ? when you cut heads to build compression, push rods and adjustable rockers have to be looked at.
logan426
[Re: JohnRR]
#980830
04/26/11 02:51 PM
04/26/11 02:51 PM
Posts: 299 Fitchbug, Mass.
WannaRunner
Fitchbug, Mass.
Describe a trouble free upgrade?
What does it have for pistons in it now? What heads do you have?
The XE grinds are known to be noisy because of the fast ramps , using them with stock stamped rockers makes it sound worse.
"Describe a trouble free upgrade?"
Is it pretty much plug and play?
"What does it have for pistons in it now?"
Stock.
"What heads do you have?"
Stock 906's
"The XE grinds are known to be noisy because of the fast ramps , using them with stock stamped rockers makes it sound worse"
Any recommendations for a rocker upgrade? a step up from stock is about as much as I'm looking for.
Thanks!
[Re: MLR426]
#980831
04/26/11 02:54 PM
04/26/11 02:54 PM
WannaRunner
Fitchbug, Mass.
logan426
Do you know the thickness for stock head gaskets? my motor is a uncut orginal, I would like to keep like that as long as I can.
Thanks!
[Re: WannaRunner]
#980832
04/26/11 03:21 PM
04/26/11 03:21 PM
Posts: 843 Suffolk,VA
ireland383
Suffolk,VA
Stock steel gasket is .020 thick.
Mopar Performance P4286754
[Re: Junky]
#980834
04/26/11 06:46 PM
04/26/11 06:46 PM
WannaRunner
Fitchbug, Mass.
The Comp XE268H cam will work just fine in a stockish 383. Yes, you can hear it tapping away because of the fast ramp lobes, but it's no big deal. I ran the XE262H which is one step down from the 268, this was with stock heads and rockers and steel shim head gaskets. It was a tapper too, but I liked it. I now run a Hughes cam.
What type of exhaust/manifolds/headers, rear gears and transmission will you be running? That will make a difference on which cam is best to run.
Stock exhaust manifolds, stock 727, (I may go with a trans go kit) 323 gears, edelbrock 1407 carb (750 cfm)
[Re: WannaRunner]
#980836
04/26/11 09:59 PM
04/26/11 09:59 PM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
The XE262H will have slightly more torque over the XE268H which will have slightly higher horse power over the 262. Personally I'd run the 262 with your combo. I ran the XE262H in my 383. It ran strong up to 5,700 RPM's. Slight noticeable idle. The 268 will work OK with high gears and low converter stall.
[Re: WannaRunner]
#980837
04/27/11 11:35 AM
04/27/11 11:35 AM
Posts: 74,978 U.S.S.A.
JohnRR
U.S.S.A.
Do yourself a favor and lose that carb , you'll be happier in the long run , it's got a bad setup from ebrock and requires drilling of passages to fix it , if you are lucky .
[Re: JohnRR]
#980838
04/27/11 05:23 PM
04/27/11 05:23 PM
WannaRunner
Fitchbug, Mass.
Any recommendations?
[Re: WannaRunner]
#980839
04/27/11 05:30 PM
04/27/11 05:30 PM
ireland383
Suffolk,VA
Holley 3310
[Re: ireland383]
#980840
04/27/11 06:07 PM
04/27/11 06:07 PM
WannaRunner
Fitchbug, Mass.
Holley 3310
I looked into the 3310, is 750 to much for my set-up?
[Re: WannaRunner]
#980845
04/28/11 01:30 PM
04/28/11 01:30 PM
JohnRR
U.S.S.A.
Anyone run a Holley 670 street avenger on a Ebrock performer RPM? Also, is it possible to do a accurate compression check with the motor out of the car by rotating the crank with a breaker bar? I forgot to do it before yanking the motor. (using the starter)
Information overload!
I doubt you will get anywhere near enough rotation speed to get anything remotely accurate . I would do a leakdown test but even then a little heat in the engine before hand would have been nice.
Is the engine original or has it been rebuilt ?
[Re: Junky]
#980846
04/28/11 04:05 PM
04/28/11 04:05 PM
WannaRunner
Fitchbug, Mass.
I've ran 4 different carburetors on the Edelbrock Performer RPM with the XE262H cam, headers, 2500 stall converter and 3.73 rear grears. The Eddy 750, Eddy 650, Holley 670 and the best one, the 3310 Holley 750. I never could get the Eddy 750 tuned the way it should have performed. To me the 650 and the 670 were too small, not enough punch off the line and not enough top end. The 3310 Holley 750 was and is perfect.
Sounds good, my choice is getting easier, thanks for taking the time to answer my Dumb ar$e questions.
