Bleeding TF 727 #980632
04/25/11 08:27 PM
04/25/11 08:27 PM
FL
74-440Charger Offline OP
FL
My TF 727 is bleeding to death! The gasket where the tailshaft connects to the trans, from the shifter shaft or the kickdown shaft. started slow, changed the pan gasket twice before I figured out there were multiple leaks. No idea how to get one of these things apart, is there a good book out there? It's been in the car about 10 years and still shifts great, how much should it cost to get it sealed up? Thanks
Re: Bleeding TF 727 [Re: 74-440Charger] #980633
04/25/11 08:32 PM
04/25/11 08:32 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Have you located the exact place where it is leaking ? ... baby powder works good.
Re: Bleeding TF 727 [Re: 74-440Charger] #980634
04/25/11 08:36 PM
04/25/11 08:36 PM
North Central Florida
E
eightlitermopar Offline
E
Don't freak out quite yet. Mine always would finally seal then die on me internally!
The shift lever seal was a problem on my brothers car, leaked like it had a bullet hole in it.
Just be careful replacing it...one tweak and you need another one.
If you need a book. The A-727 book by Carl H. Munroe is what I used during my rebuild.
eight
Mopar or no car
Re: Bleeding TF 727 [Re: eightlitermopar] #980635
04/25/11 08:50 PM
04/25/11 08:50 PM
FL
FL
Thanks, I'll look for the book, hate to throw money at any of the trans shops around here. Only checked one shop so far but he wanted $700 + parts to tear it down inspect and seal it up. More if it needed more work. For that price I may as well buy a new one.
Re: Bleeding TF 727 [Re: 74-440Charger] #980636
04/25/11 09:28 PM
04/25/11 09:28 PM
What Doc said, car wash wand clean it, bring it home, spray it w baby powder, run it, find (& post) where the leak is. someone (on here) had a good trick for getting the powder up in there but I dont remem what it was. find/deal w the leak & you're all set & I'd do that b 4 I splurged for the book. EDIT some leaks you need to let it sit w the baby powder overnight & check it in the AM
Re: Bleeding TF 727 [Re: 74-440Charger] #980637
04/25/11 09:37 PM
04/25/11 09:37 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
700 beans ? ... and maybe more ? .... to that shop. NOTHING but CROOKS ..
IF IT IS that shifter seal ... there is MORE to it than just a new seal. NOT to worry ,.... it is just a time on your part to do-it right !
Re: Bleeding TF 727 [Re: eightlitermopar] #980638
04/25/11 09:57 PM
04/25/11 09:57 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
eight
Not sure about the Munroe book but do NOT get the ASTG book. It is only a reprint of the service manual with a few service bulletins included. At least the factory service manual has a tutorial on the hydraulic circuits and model specific items like shifter linkage that the ASTG does not.
Craig
