no low gear in 727? #980275
04/25/11 03:10 PM
04/25/11 03:10 PM
jacksboro,tn
1bad318 Offline OP
1bad440
1bad318  Offline OP
1bad440
jacksboro,tn
i just test drove the satellite and it pulled good in low for a minute then it felt like something let loose and now i have no low gear.put it in drive and it tries to pull out but feels like 2nd.pull it in low and it just revs.i have reverse just fine,but could it be the low reverse band? fluid looks great and dont smell burnt
Re: no low gear in 727? [Re: 1bad318] #980276
04/25/11 03:13 PM
04/25/11 03:13 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
Your sprag is toast ... pull the pan and see what is in there.
Re: no low gear in 727? [Re: dOc …] #980277
04/25/11 03:16 PM
04/25/11 03:16 PM
jacksboro,tn
1bad318 Offline OP
1bad440
1bad318  Offline OP
1bad440
jacksboro,tn
crap.i havent got time to pull it today,have to do it later.but thats a big set-back.working 7 days a week i don't have alot of time to do anything. i dread dropping that trans again
Re: no low gear in 727? [Re: 1bad318] #980278
04/25/11 03:23 PM
04/25/11 03:23 PM
Florida STAYcation
dOc … Offline
dOc …  Offline
Florida STAYcation
Popping the trans out is not fun but probably will be needed. If you do your own trans work ... it is not that big-of-a-fix.
BTW ... how far up is Douglas Lake ?
Re: no low gear in 727? [Re: dOc …] #980279
04/25/11 03:27 PM
04/25/11 03:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If the sprag had failed it wouldn't pull in Drive but would in manual low. (assuming a fully auto valve body)
Re: no low gear in 727? [Re: John_Kunkel] #980280
04/26/11 04:12 AM
04/26/11 04:12 AM
jacksboro,tn
1bad318 Offline OP
1bad440
1bad318  Offline OP
1bad440
jacksboro,tn
yes,its a stock trans with full auto valve body.i do my own trans work.i checked the clutches and steels and bands before i put it in,they looked good.ill find out when i drop it.wont take but 30-45 minutes if im in the right mood.doc,i dont know where douglas lake is,im rite next to norris,but i do know they opened the flood gates at norris dam,so its got kinda high.
Re: no low gear in 727? [Re: 1bad318] #980281
04/26/11 03:59 PM
04/26/11 03:59 PM
Florida STAYcation
dOc … Offline
dOc …  Offline
Florida STAYcation
JK ... he says that it is a no-go in manual low.
1bad .... Jacksboro !! .... I must have had a "Rocky" moment .... I have been to J-boro and Norris Lake. During that ROCKY MOMENT I placed J-boro near Douglas Lake...which is instead near Sevierville and Gatlinburg. BTW ... how are property values on N-lake?
Re: no low gear in 727? [Re: dOc …] #980282
04/26/11 04:35 PM
04/26/11 04:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I know, that's why I don't think it's a sprag; more likely a rear clutch problem.
Re: no low gear in 727? [Re: John_Kunkel] #980283
04/26/11 04:42 PM
04/26/11 04:42 PM
Florida STAYcation
dOc … Offline
dOc …  Offline
Florida STAYcation
.....I think I am having another ROCKY MOMENT ..... I am not as REfreshed as I thought....after getting up about an hour ago.
JK is uNwrong .... 1bad probably BLEW OUT the seal.
