Removing newer seam sealer pv? #979961
04/24/11 11:03 PM
04/24/11 11:03 PM
K&Q va.
BIGBLOCK_KAT Offline OP
K&Q va.
Drilling out spot welds on a newer mopar. what is best to apply on it so it will disolve? it's still soft. tried a wire cup and it went everywhere
Re: Removing newer seam sealer pv? [Re: BIGBLOCK_KAT] #979962
04/24/11 11:10 PM
04/24/11 11:10 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Re: Removing newer seam sealer pv? [Re: Neil] #979963
04/24/11 11:44 PM
04/24/11 11:44 PM
K&Q va.
K&Q va.
Actually looking for a chemical application.....may try car quest , or napa parts. I have seen those wheels, I'll see what the price is of both. the stuff is gummy though.
Re: Removing newer seam sealer pv? [Re: BIGBLOCK_KAT] #979964
04/25/11 08:21 PM
04/25/11 08:21 PM
md
W
wicked Offline
wicked  Offline
W
md
Only way I know is wire brush, There is a specific tool used for this , but when you get down to it just a wire brush, Yeah it's messy it's and gets all over. Most are urethane based and designed to stay soft. Never heard of a chemical app that would touch this stuff. It would be hard to neutralize if it got into the seam and I would imagine also remove paints. tape down some plastic sheeting around the area or old sheets or something to contain the mess
Re: Removing newer seam sealer pv? [Re: BIGBLOCK_KAT] #979965
04/26/11 12:07 AM
04/26/11 12:07 AM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
heat gun and a chisel
