Were you able to install your ACC carpet correctly?
#979498
04/24/11 02:10 PM
04/24/11 02:10 PM
Posts: 1,307 BC, Canada
Black_Bee
BC, Canada
Hey guys! for the last couple of nights Ive been installing a new carpet in my '69 Super Bee w/ auto. I see the Moparts posts related to proper positioning of the gas pedal on the heel pad, and have attempted to duplicate those, with the pedal located on the front right side of the pad. My problem is that when I finally get the carpet far enough forward to position the pedal on the pad, the front carpet no longer overlaps the rear and the molding of the carpet no longer matches the contours of the floor. Looks to me like the heel pad on this carpet is installed maybe a few inches too far back. is this common to all ACC carpets? I ended up having to install the gas pedal with it just barely overlapping the front of the heel pad. Thanks! Paul
Paul '69 Super Bee 383 EFI Turbo
Re: Were you able to install your ACC carpet correctly?
[Re: Black_Bee]
#979501
04/24/11 02:55 PM
04/24/11 02:55 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
Put ACC in my Charger and had enough to go everywhere and look right.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
[Re: Black_Bee]
#979504
04/24/11 03:53 PM
04/24/11 03:53 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
FWIW it sounds like you tried to do match the factory position.. I saved this photo a couple years ago, an original carpet with the factory cutout for the accelerator pedal...
[Re: 1_WILD_RT]
#979505
04/24/11 06:44 PM
04/24/11 06:44 PM
Posts: 6,097 Valencia, España
NachoRT74
Valencia, España
my answer is simply enought like: NO I WASN'T ABLE TO MATCH IT... at least the front section... rear section fit perfect
[Re: Black_Bee]
#979506
04/25/11 02:21 AM
04/25/11 02:21 AM
Black_Bee
BC, Canada
Thanks guys! You wonder why they cant make carpet that just fits... with all the trimming and holes punched out. If they could do it for the assembly line when the cars were new, why cant they do it today? I know its supposed to be due to production tolerances in the cars, but come on... how far off are tolerances on the floor pan really? Thanks!
