Were you able to install your ACC carpet correctly? #979498
04/24/11 02:10 PM
04/24/11 02:10 PM
BC, Canada
Black_Bee Offline OP
BC, Canada
Hey guys!
for the last couple of nights Ive been installing a new carpet in my '69 Super Bee w/ auto. I see the Moparts posts related to proper positioning of the gas pedal on the heel pad, and have attempted to duplicate those, with the pedal located on the front right side of the pad.
My problem is that when I finally get the carpet far enough forward to position the pedal on the pad, the front carpet no longer overlaps the rear and the molding of the carpet no longer matches the contours of the floor.
Looks to me like the heel pad on this carpet is installed maybe a few inches too far back. is this common to all ACC carpets? I ended up having to install the gas pedal with it just barely overlapping the front of the heel pad.
Thanks!
Paul
Paul
'69 Super Bee 383 EFI Turbo
Re: Were you able to install your ACC carpet correctly? [Re: Black_Bee] #979499
04/24/11 02:14 PM
04/24/11 02:14 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
My heel pad was never anywhere close to my gas pedal. There's a floor mat over it afterward anyway so I couldn't care less.
Re: Were you able to install your ACC carpet correctly? [Re: Black_Bee] #979500
04/24/11 02:29 PM
04/24/11 02:29 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
This company has had quality control issues for years. I have bought several sets and had mixed results. My 70 Charger carpet, bought in 2003, was/is too short on the sides and toward the front. It stops just barely above the gas pedal. From the back seat, you SHOULDN'T see the bare firewall. You can in my car. I'd replace it if I knew that the new set would fit better.
Re: Were you able to install your ACC carpet correctly? [Re: Black_Bee] #979501
04/24/11 02:55 PM
04/24/11 02:55 PM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
Put ACC in my Charger and had enough to go everywhere and look right.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Were you able to install your ACC carpet correctly? [Re: Kern Dog] #979502
04/24/11 03:03 PM
04/24/11 03:03 PM
Washington
69440 Offline
69440  Offline
Washington
ACC carpets are ALWAYS either too stort, or too narrow, or both. I stopped using them years ago for this exact problem. One of the better "inexpensive" carpet kits is Auto Carpet Systems. I haven't tried one from ECS, but I'm told they not only fit perfectly, but there's also enough there that some trimming is needed.
Re: Were you able to install your ACC carpet correctly? [Re: 69440] #979503
04/24/11 03:14 PM
04/24/11 03:14 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Bought my set over 20 years ago - the underpadding was all in the wrong places.
I see quality hasn't changed !!
Re: Were you able to install your ACC carpet correctly? [Re: Black_Bee] #979504
04/24/11 03:53 PM
04/24/11 03:53 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
FWIW it sounds like you tried to do match the factory position.. I saved this photo a couple years ago, an original carpet with the factory cutout for the accelerator pedal...
Re: Were you able to install your ACC carpet correctly? [Re: 1_WILD_RT] #979505
04/24/11 06:44 PM
04/24/11 06:44 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
my answer is simply enought like: NO I WASN'T ABLE TO MATCH IT... at least the front section... rear section fit perfect
Re: Were you able to install your ACC carpet correctly? [Re: Black_Bee] #979506
04/25/11 02:21 AM
04/25/11 02:21 AM
BC, Canada
BC, Canada
Thanks guys!
You wonder why they cant make carpet that just fits... with all the trimming and holes punched out.
If they could do it for the assembly line when the cars were new, why cant they do it today? I know its supposed to be due to production tolerances in the cars, but come on... how far off are tolerances on the floor pan really?
Thanks!
Paul
