STAGE VI HEADS #978520
04/23/11 03:41 AM
04/23/11 03:41 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
Finally got the 440 to a buddies to change check valve springs and do a leak down. Well the leak do was interesting after roughly 90 passes 6 cylinders are at 15 to 20 percent leakage and 2 are almost 60 percent. The heads don't seem to hold a valve job, anyone else with stage vi or aluminum heads period having a problem.
Re: STAGE VI HEADS [Re: rickb67] #978521
04/23/11 02:33 PM
04/23/11 02:33 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
no idea I hope it's not an issue. I have a set on my 440-6. Sure the intake is sealed up nice? Valley pan sealed?
Coming soon!!!!
Re: STAGE VI HEADS [Re: rickb67] #978522
04/23/11 02:55 PM
04/23/11 02:55 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
you are not the only one with prob's from those heads,my buds a guru w parts,and he told me thats the prob mopar had w those heads...thats sucks man..good luck
Re: STAGE VI HEADS [Re: rickb67] #978523
04/23/11 03:25 PM
04/23/11 03:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Did you have the valves ground before you put the
heads on.... MP has a bad valve job on most all of
their heads from the factory(if you want to call it
a valve job)
Re: STAGE VI HEADS [Re: MR_P_BODY] #978524
04/23/11 06:08 PM
04/23/11 06:08 PM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
I bought the engine from a guy 3 years ago that said it had 35 passes on it.We cut the filer open looked at it (looked fine)never did a leak test. Unloaded saturday night and it didn't sound good so we did a leak test and found intake vales leaking.Did a valve job and Put it back in ran great for aawile (90 passes near as I can tell).Just not sure what to do if they will still have issues.
Re: STAGE VI HEADS [Re: rickb67] #978525
04/24/11 08:31 PM
04/24/11 08:31 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
the intake seat inserts often "move" on stage 6 heads.
either intake or exhaust can be the culprit, but its usually the intakes that have the issue.
if the heads have had intake valves larger than 2.14 installed, and had the seats cut accordingly, then you can pretty much count on the seats moving.
recheck the biggest offenders and see where it seems like the air is going.
if its out the intake manifold......then the seats have moved.
the only real cure is to install new, bigger seats with more of an interference fit.
Re: STAGE VI HEADS [Re: fast68plymouth] #978526
04/25/11 01:27 AM
04/25/11 01:27 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
Well that figures. If i sent you these heads can you fix them and how much would it cost.
Re: STAGE VI HEADS [Re: rickb67] #978527
04/25/11 07:46 AM
04/25/11 07:46 AM
tboomer Offline
tboomer  Offline
Dwaynes phone number is in his profile. Give him a call! You won't talk to a nicer,knowledgable person! R&J Performance in Hudson,Iowa did my Stage VIs..But you would have to wait a long time. He is up to his ears in S&S Pro Stock Harley heads now...There is also a guy in Carrol,Iowa that may be able to do them. I will see if I can find his number...Ted
Re: STAGE VI HEADS [Re: rickb67] #978528
04/25/11 10:54 AM
04/25/11 10:54 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Have him port them while they are there! You won't be sorry!! (I certainly wasnt!!)
