Re: STAGE VI HEADS
[Re: rickb67]
#978522
04/23/11 02:55 PM
04/23/11 02:55 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
Finally got the 440 to a buddies to change check valve springs and do a leak down. Well the leak do was interesting after roughly 90 passes 6 cylinders are at 15 to 20 percent leakage and 2 are almost 60 percent. The heads don't seem to hold a valve job, anyone else with stage vi or aluminum heads period having a problem.
you are not the only one with prob's from those heads,my buds a guru w parts,and he told me thats the prob mopar had w those heads...thats sucks man..good luck
Re: STAGE VI HEADS
[Re: rickb67]
#978523
04/23/11 03:25 PM
04/23/11 03:25 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Did you have the valves ground before you put the heads on.... MP has a bad valve job on most all of their heads from the factory(if you want to call it a valve job)
Re: STAGE VI HEADS
[Re: rickb67]
#978525
04/24/11 08:31 PM
04/24/11 08:31 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
the intake seat inserts often "move" on stage 6 heads. either intake or exhaust can be the culprit, but its usually the intakes that have the issue. if the heads have had intake valves larger than 2.14 installed, and had the seats cut accordingly, then you can pretty much count on the seats moving.
recheck the biggest offenders and see where it seems like the air is going. if its out the intake manifold......then the seats have moved. the only real cure is to install new, bigger seats with more of an interference fit.
Re: STAGE VI HEADS
[Re: rickb67]
#978528
04/25/11 10:54 AM
04/25/11 10:54 AM
Posts: 13,200 aZLiViN
J_BODY
aZLiViN
Well that figures. If i sent you these heads can you fix them and how much would it cost.
Have him port them while they are there! You won't be sorry!! (I certainly wasnt!!)
