B-Body torsion bar help #978291
04/22/11 07:22 PM
04/22/11 07:22 PM
Akron, Ohio U.S.A.
roadhazard Offline OP
Akron, Ohio U.S.A.
Hello all!
Looking for a little help with the torsion bars that should be used in my '71 Charger.
Was original 318 and now 440 and need to upgrade the bars to sute the current combo.
Guess the question is what diameter are the big block bars supposed to be and what would be the number on them. Also would it be advisable/advantageous to go larger than the O.E.M. standard size and what should I look for?
Always appreciate the help!
Greg
Re: B-Body torsion bar help [Re: roadhazard] #978292
04/22/11 07:26 PM
04/22/11 07:26 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
The 7/8 were the top diameter back in the day (HEMIs etc.). I know that aftermarkets ones are even stiffer. They cost a couple hundred, and I would like to know if the one's over an inch are worth it.
Re: B-Body torsion bar help [Re: DANA60] #978293
04/22/11 10:35 PM
04/22/11 10:35 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
I put the 1.03 bars from Just Suspension that were on sale for $199 in my b and e body cars and could not be happier! Thought it would have a rougher ride, that did not happen, but a huge improvement in handling and stability. Money well spent.
Re: B-Body torsion bar help [Re: Lee446] #978294
04/22/11 11:02 PM
04/22/11 11:02 PM
Akron, Ohio U.S.A.
Akron, Ohio U.S.A.
Too bad they are $350.00 at the big S
Budget is not in line with that unfortunately unless someone has a used pair they would like to part with
Re: B-Body torsion bar help [Re: roadhazard] #978295
04/22/11 11:36 PM
04/22/11 11:36 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Hello all!
Greg
The big block 440 bars are .092 in diameter, Stamped ID NO. 780/781
Your stock 318 bars are .088 in diameter, with a Stamped ID NO.776/777
There was also a seperate bar for the lighter 383 BB Witch was .090 in diameter, stamped with ID NO. 778/779
As for your question of what bar to go with, it will depend on the overall front end weight change your actually going to have.
With my Abody 440 swap from its original 318. Im still using the 318 bars.
The 318 was loaded, Air conditioning/Power steering/Power brakes/Emissions crap.
VS none of the above with just a 440 with aluminum heads /intake and battery in the trunk.
Depending on the total swap perameters maybe the current 318 bars will be fine.
Re: B-Body torsion bar help [Re: Sport440] #978296
04/23/11 12:07 AM
04/23/11 12:07 AM
Kansas
BEINGmeISaCRIME Offline
Kansas
FWIW - my 72 charger, being an original 318 car, that the torsion bars that were the bars that the big block used, like 0.92" I believe.
Re: B-Body torsion bar help [Re: BEINGmeISaCRIME] #978297
04/23/11 12:19 AM
04/23/11 12:19 AM
Pataskala, Ohio
GTX70sixpack Offline
Pataskala, Ohio
If you are going to drive it to enjoy it, you will need bigger than92's and a bigger front sway bar and a rear sway bar added. Don't forget to replace the rear springs too. Most importantly the big front disc. are a must.
65 Belvedere II Station Wagon
69 Coronet R/T convertible
70 GTX
70'cuda
99 Dodge Diesel dually 4X4
Re: B-Body torsion bar help [Re: Sport440] #978298
04/23/11 12:27 AM
04/23/11 12:27 AM
Akron, Ohio U.S.A.
Akron, Ohio U.S.A.
Thanks Sport440
Now I'm loaded with a little info I'll hit the garage in the morning with my creeper and calipers
Thanks all
Re: B-Body torsion bar help [Re: roadhazard] #978299
04/23/11 01:37 AM
04/23/11 01:37 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I have the Mopar 0.96" bars on my '71 Charger with a 400 stroked to 500", and the PST sway bars, rides much nicer than with the smaller 383 T-bars.
Re: B-Body torsion bar help [Re: 451Mopar] #978300
04/23/11 08:50 AM
04/23/11 08:50 AM
BDW Offline
BDW  Offline
I put the 0.92 bars into my SB E-body, love the ride. I would suggest you go >1"
Here's some info for reference
Re: B-Body torsion bar help [Re: BDW] #978301
04/24/11 01:46 PM
04/24/11 01:46 PM
Akron, Ohio U.S.A.
Akron, Ohio U.S.A.
Thanks again for ALL the replies
I had the .880 bars in there so anything larger will be an improvement
I'm looking @ going with the .960 Mopar Perf. bars unless there are issues with them quality wise.
This is a 46,000 mile driver with the original rear springs in excellent shape. I don't want to over spring the front and plan to add a front sway bar for roll resistance in the future.
No corner carving. Just looking for a good ride without plowing the front end turning a corner or getting on a highway ramp
