Dana 60 BOM numbers #977242
04/21/11 01:24 AM
04/21/11 01:24 AM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
I need some help identifying a dana 60 I just picked up. I have looked all over the net and can't find this number. The bom number is 602829. Date code looks like it was 3-20-7. All the numbers I have found start with 68 production year. Thanks, Beep
Re: Dana 60 BOM numbers [Re: Bigbeep] #977243
04/21/11 01:47 AM
04/21/11 01:47 AM
Renton Washington
Triple Threat Offline
Renton Washington
I cant get this to work, but maybe you can.
http://www2.dana.com/expertforms/deabill.aspx
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Dana 60 BOM numbers [Re: Triple Threat] #977244
04/21/11 02:02 AM
04/21/11 02:02 AM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
Been there. Their site only goes back to 79. Thanks, Beep
Re: Dana 60 BOM numbers [Re: Bigbeep] #977245
04/21/11 06:39 AM
04/21/11 06:39 AM
BDW Offline
BDW  Offline
Re: Dana 60 BOM numbers [Re: Bigbeep] #977246
04/21/11 08:25 AM
04/21/11 08:25 AM
N
NITROUSN Offline
NITROUSN  Offline
N
How sure are you on that bom numbers??
Re: Dana 60 BOM numbers [Re: NITROUSN] #977247
04/21/11 09:40 AM
04/21/11 09:40 AM
Vernon Ct.
bp27 Offline
bp27  Offline
Vernon Ct.
Does it have a drain plug and a pinion snubber mount?
Re: Dana 60 BOM numbers [Re: Bigbeep] #977248
04/21/11 11:12 AM
04/21/11 11:12 AM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
BOM back to '67 are in this catalog http://www2.dana.com/pdf/X510-8DSD.pdf
Re: Dana 60 BOM numbers [Re: NITROUSN] #977249
04/21/11 11:04 PM
04/21/11 11:04 PM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
Numbers are pretty clear. one date code is 3-10-7 and the second date code is 3-20-7. I am pretty sure it was a 3.54 gear originally, now 5.13.
I also have a 602957 bom unit that came from 69 that is all original with 3.54 with a date code of 3-25-9. Beep
Re: Dana 60 BOM numbers [Re: bp27] #977250
04/21/11 11:15 PM
04/21/11 11:15 PM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
Yes to both.
23 spline and a powerloc with a 2-24-67 date code. Now has a 5.13 gear with a ring gear spacer on it.
Other than the gear and the spring perches being removed, it looks stock.
Beep
Re: Dana 60 BOM numbers [Re: 446acuda] #977251
04/21/11 11:20 PM
04/21/11 11:20 PM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
I had looked at that page and it doesn't list any car axles for 66-67. They start with the 602957 BOM for the 68 model year. I figured someone on here would have went thru this before now. Is there anyone on here with a 67 dana car? Beep
Re: Dana 60 BOM numbers [Re: Bigbeep] #977252
04/21/11 11:26 PM
04/21/11 11:26 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
Anyone know the BOM number for the '68 SS a-bodies?
Re: Dana 60 BOM numbers [Re: Bigbeep] #977253
04/21/11 11:30 PM
04/21/11 11:30 PM
eganville ont
440beep Offline
440beep  Offline
eganville ont
69 dana60 is 602957
70 dana 60 is 603109
71-72 dana 60 603222
Plymouth's gonna getcha! There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters 71 gtx 440 4speed air grabber blue on blue with white vinyl roof
Re: Dana 60 BOM numbers [Re: Bigbeep] #977254
04/21/11 11:31 PM
04/21/11 11:31 PM
Vernon Ct.
bp27 Offline
bp27  Offline
Vernon Ct.
Yes to both.
Beep
It's a 67 b-body
Re: Dana 60 BOM numbers [Re: bp27] #977255
04/22/11 01:46 PM
04/22/11 01:46 PM
eganville ont
440beep Offline
440beep  Offline
eganville ont
Auction Ended: 16 June 2006
# Bids: 22
Sold For: $72,099
Miles: 24800
VIN: XP29J721149176
Engine: 8
Transmission: manual
Exterior Color: black
Interior Color: black
1967 Dodge Charger 426 hemi 4 speed, black on black. I bought this car from the second owner. He owned the car since 1980. It has a little over 24 thousand orginal miles on the car. The car still has the orginal weather stripping. It has the correct motor, trans ,rearend, everything that came with the car new back in 1967. The car was repainted about 3 yrs ago before I got it. From looking at the car in the trunk it looks like it was orginally a green car. The car drives great for a big car it moves out nice hey its got a hemi in it..
The numbers I found on the motor are as follows Cast Date 10-3-66 Build Date 11-15-66 this number is cast on both sides of block 2468330-2
The trans numbers are passenger side A 3
C- 97372 above that number painted on is 394
On the drivers side of the trans on clutch cover C 956642 1y18
Dana 60 rearend the numbers are build date 8-26-66
Bill of material 602829-1
so the 66-67 dana 60 are 602829-1
Re: Dana 60 BOM numbers [Re: 440beep] #977256
04/23/11 12:13 PM
04/23/11 12:13 PM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
# Bids: 22
Sold For: $72,099
Miles: 24800
VIN: XP29J721149176
Engine: 8
Thank you. I assume that yours has the 3.54 gear as it is a -1 suffix.
Also, sounds like a killer ride. Thanks again, Beep
Re: Dana 60 BOM numbers [Re: 440beep] #977257
02/07/12 09:50 PM
02/07/12 09:50 PM
Wayne, Michigan USA
K
KryslerKid Offline
KryslerKid  Offline
K
Wayne, Michigan USA
I agree with 440beep. I have a 602829-7 dated Feb 16 of '66. I was told my rear was originally a 4.10 but making it a 3.54. The best I can come up with is this # is a 66-67 PowerLock rearend. Just my 2 cents added to the Mopar Chronicles!
KK
