Re: Dana 60 BOM numbers
[Re: Bigbeep]
#977248
04/21/11 11:12 AM
04/21/11 11:12 AM
Posts: 2,734 Charlotte, NC
446acuda
Charlotte, NC
I need some help identifying a dana 60 I just picked up. I have looked all over the net and can't find this number. The bom number is 602829. Date code looks like it was 3-20-7. All the numbers I have found start with 68 production year. Thanks, Beep
BOM back to '67 are in this catalog http://www2.dana.com/pdf/X510-8DSD.pdf
[Re: NITROUSN]
#977249
04/21/11 11:04 PM
04/21/11 11:04 PM
Posts: 1,165 Central Ohio, USA
Bigbeep
Central Ohio, USA
How sure are you on that bom numbers??
Numbers are pretty clear. one date code is 3-10-7 and the second date code is 3-20-7. I am pretty sure it was a 3.54 gear originally, now 5.13.
I also have a 602957 bom unit that came from 69 that is all original with 3.54 with a date code of 3-25-9. Beep
[Re: bp27]
#977250
04/21/11 11:15 PM
04/21/11 11:15 PM
Bigbeep
Central Ohio, USA
Does it have a drain plug and a pinion snubber mount?
Yes to both.
23 spline and a powerloc with a 2-24-67 date code. Now has a 5.13 gear with a ring gear spacer on it.
Other than the gear and the spring perches being removed, it looks stock. Beep
[Re: 446acuda]
#977251
04/21/11 11:20 PM
04/21/11 11:20 PM
Bigbeep
Central Ohio, USA
I had looked at that page and it doesn't list any car axles for 66-67. They start with the 602957 BOM for the 68 model year. I figured someone on here would have went thru this before now. Is there anyone on here with a 67 dana car? Beep
[Re: Bigbeep]
#977253
04/21/11 11:30 PM
04/21/11 11:30 PM
Posts: 1,183 eganville ont
440beep
eganville ont
69 dana60 is 602957 70 dana 60 is 603109 71-72 dana 60 603222 ![](/ubbthreads/images/graemlins/beer.gif)
Plymouth's gonna getcha!
There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters
71 gtx 440 4speed air grabber blue on blue with white vinyl roof
[Re: Bigbeep]
#977254
04/21/11 11:31 PM
04/21/11 11:31 PM
Posts: 184 Vernon Ct.
bp27
Vernon Ct.
Yes to both.
It's a 67 b-body
[Re: bp27]
#977255
04/22/11 01:46 PM
04/22/11 01:46 PM
440beep
eganville ont
Auction Ended: 16 June 2006 # Bids: 22 Sold For: $72,099 Miles: 24800 VIN: XP29J721149176 Engine: 8 Transmission: manual Exterior Color: black Interior Color: black
1967 Dodge Charger 426 hemi 4 speed, black on black. I bought this car from the second owner. He owned the car since 1980. It has a little over 24 thousand orginal miles on the car. The car still has the orginal weather stripping. It has the correct motor, trans ,rearend, everything that came with the car new back in 1967. The car was repainted about 3 yrs ago before I got it. From looking at the car in the trunk it looks like it was orginally a green car. The car drives great for a big car it moves out nice hey its got a hemi in it..
The numbers I found on the motor are as follows Cast Date 10-3-66 Build Date 11-15-66 this number is cast on both sides of block 2468330-2 The trans numbers are passenger side A 3 C- 97372 above that number painted on is 394 On the drivers side of the trans on clutch cover C 956642 1y18 Dana 60 rearend the numbers are build date 8-26-66 Bill of material 602829-1
so the 66-67 dana 60 are 602829-1
[Re: 440beep]
#977256
04/23/11 12:13 PM
04/23/11 12:13 PM
Bigbeep
Central Ohio, USA
Thank you. I assume that yours has the 3.54 gear as it is a -1 suffix.
Also, sounds like a killer ride. Thanks again, Beep
