emblem removal #977043
04/20/11 03:19 PM
04/20/11 03:19 PM
so cal,cali
calimoparguy Offline OP
so cal,cali
on the newer cars(charger,magnum,300 etc) whats the best way to remove the exterior emblems with out damaging then or car,thanks
Re: emblem removal [Re: calimoparguy] #977044
04/20/11 03:56 PM
04/20/11 03:56 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Use a hair dryer to heat up the emblem. Use a plastic body filler applicator to get a corner started and it should just peel off.
I don't know if you'll be able to save the emblems though. When you warm them up and start pulling them off, they stretch.
Re: emblem removal [Re: calimoparguy] #977045
04/20/11 04:48 PM
04/20/11 04:48 PM
morrisville, pa
skajm Offline
skajm  Offline
morrisville, pa
try using dental floss to cut the glue tape. used that to remove the ram charger off the fender of the truck.
Re: emblem removal [Re: skajm] #977046
04/20/11 04:55 PM
04/20/11 04:55 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
There is a rubber wheel you can get that will take the residue off the paint without scratching.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: emblem removal [Re: Savoy1964] #977047
04/20/11 11:31 PM
04/20/11 11:31 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
C) All of thew above..
Re: emblem removal [Re: calimoparguy] #977048
04/21/11 03:00 PM
04/21/11 03:00 PM
Iowa
GreenBird Offline
GreenBird  Offline
Iowa
I use fishing line. It will cut the emblem loose from the tape. Then, rub the tape off with friction from your finger and some rubbing alcohol.
