E body disc brakes #977036
04/20/11 02:46 PM
04/20/11 02:46 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..Do they all use the same spindles or do earlier spindles
use smaller wheel bearings?(70,71)
Re: E body disc brakes [Re: can.al] #977037
04/20/11 03:52 PM
04/20/11 03:52 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
70, 71, 72, use the smaller diameter inner wheel bearing.
73, 74, use the larger diameter inner wheel bearing.
So 70, 71, 72, spindles are the same.
73, 74, spindles are the same.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: E body disc brakes [Re: can.al] #977038
04/20/11 07:12 PM
04/20/11 07:12 PM
AndyF Offline
AndyF  Offline
E body was a "parts bin" car to save development money. So a lot of parts are the same as used on other models.
For disc brake knuckles, E body 1972 and earlier are the smll bearing B body parts. 1973 and later are the big bearing A body parts.
Re: E body disc brakes [Re: AndyF] #977039
04/21/11 08:20 AM
04/21/11 08:20 AM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
Just to add to this...
I'm restoring my 70 B body that has the smaller spindle and two piece rotors.
Moparts members tell me to buy a spindle sleeve from DR DIFF that allows you to use the less expensive and more reliable one piece rotor used on 73 and up mopar.
I ordered the spindle sleeve yesterday. I'll let you know how I make out.
Re: E body disc brakes [Re: Finoke] #977040
04/21/11 09:30 AM
04/21/11 09:30 AM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..thanks,exactly the info i was looking for.
i'm considering buying a '72 Cuda...an older resto that needs brakes so thought i'd do a little research.
