Need a 15'' or bigger spare tire what car should i look #976868
04/20/11 10:27 AM
04/20/11 10:27 AM
IL . usa
cjs69mope Offline OP
IL . usa
hey all i need to get a used 15 inch rim or larger to mount a spare tire for use on my 69 charger. I have not had a spare since the car was built with custom 17 inch wheels .
So I want to get a tall tire mounted on a plain Jane 15 in rim to have in case of a flat .
My question is where is the most reasonable place to find a rim that will fit . I don't go to bone yards anymore so I don't know what car would fit . any suggestions ? would a spare from a dodge ram truck or van work ? or any passenger car ?
1969 Dodge Charger 1969 Dodge Superbee
Re: Need a 15'' or bigger spare tire what car should i look [Re: cjs69mope] #976869
04/20/11 11:13 AM
04/20/11 11:13 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
15" rims that will fit come of Diplomats and Gran Furies , there is also a 16" on the newer jeep wranglers that will work .
Re: Need a 15'' or bigger spare tire what car should i look [Re: cjs69mope] #976870
04/20/11 11:25 AM
04/20/11 11:25 AM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
Some of the Dodge Trucks and Vans have wheels which will fit. On trucks it's 1984 back 2 wheel drive and 1980 back 4x4. I'm not certain of the years for vans, but I believe it's similar.
The newer trucks have a larger bolt pattern and/or have the wrong offset.
Re: Need a 15'' or bigger spare tire what car should i look [Re: QuickDodge] #976871
04/20/11 11:53 AM
04/20/11 11:53 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
You could also get a 15" doenut spare out of an 80-83 Mirada/Cordoba. They're pretty tall I think. It should fit and give you more trunk space at the same time. Trunk space is probably not an issue with a B-body though.
Re: Need a 15'' or bigger spare tire what car should i look [Re: burdar] #976872
04/21/11 02:54 PM
04/21/11 02:54 PM
IL . usa
IL . usa
Thank you for the help MOPARTS!
