best plugs for stock 318?
#976720
04/20/11 01:15 AM
04/20/11 01:15 AM
Posts: 1,630 North Central Florida
eightlitermopar
does it really matter for a pure stock, 4 barrell 318? I am thinking NGK... How about wires? Good NAPA replacement? Same for CAP and ROTOR? Would throwing a MSD blaster 2 coil make any difference? Or would it hurt it? I am working the spring bugs out, and thought a slight tune up would be in order. After all, the outside plugs look rusty...I have no idea how old they are. eightlitermopar
Mopar or no car
Re: best plugs for stock 318?
[Re: eightlitermopar]
#976721
04/20/11 02:55 AM
04/20/11 02:55 AM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Champion plugs, NAPA tuneup components will be fine, keep your stock coil
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: drago]
#976723
04/20/11 09:17 AM
04/20/11 09:17 AM
Posts: 15,487 Florida
scratchnfotraction
been running autolite #65 in mine for yrs..no problems I run the Beldin set of wires from napa..life time warranty I also run a pertronix points conversion with the flame thrower 40,000 volt coil tune ups are a cap/wires/plugs only evry 2 yrs so far
[Re: 69L78Nova]
#976728
04/21/11 01:51 AM
04/21/11 01:51 AM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
had too many problems with Champion.
Such as??? Ive never had a problem with them, and I have run them in everything from stock street cars to 8,000rpm race cars.
Uneven gaps from the factory (shoddy QA), easier to foul than other brands in the same situations, and I've had exactly 2 brands of plugs where the porcelain has been broken around the center electrode, sliding down when the plug was held spark end down, sliding back up to normal with wire end down. I've seen 6 plugs brand new broken this way, 2 tune-up masters (made in Eastern Europe) and 4 Champions (at 3 different times). You can say it was due to rough handling or packaging, but I have not seen it on any other plugs. The porcelain also tends break easier when removing.
