best plugs for stock 318? #976720
04/20/11 01:15 AM
04/20/11 01:15 AM
North Central Florida
E
eightlitermopar Offline OP
E
does it really matter for a pure stock, 4 barrell 318? I am thinking NGK...
How about wires? Good NAPA replacement? Same for CAP and ROTOR?
Would throwing a MSD blaster 2 coil make any difference? Or would it hurt it?
I am working the spring bugs out, and thought a slight tune up would be in order. After all, the outside plugs look rusty...I have no idea how old they are.
eightlitermopar
Mopar or no car
Re: best plugs for stock 318? [Re: eightlitermopar] #976721
04/20/11 02:55 AM
04/20/11 02:55 AM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Champion plugs, NAPA tuneup components will be fine, keep your stock coil
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: best plugs for stock 318? [Re: eightlitermopar] #976722
04/20/11 05:28 AM
04/20/11 05:28 AM
Goat Rodeo
drago Offline
drago  Offline
Goat Rodeo
Autolite sparkplugs. They're worth six extra horsepower.
Re: best plugs for stock 318? [Re: drago] #976723
04/20/11 09:17 AM
04/20/11 09:17 AM
scratchnfotraction Offline
been running autolite #65 in mine for yrs..no problems
I run the Beldin set of wires from napa..life time warranty
I also run a pertronix points conversion with the flame thrower 40,000 volt coil
tune ups are a cap/wires/plugs only evry 2 yrs so far
Re: best plugs for stock 318? [Re: drago] #976724
04/20/11 09:45 AM
04/20/11 09:45 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Champion RN14YC. More than likely came with N14Y OEM. No problems with Champions. Been running them for ever and that is OEM equipment for Mopar.
Re: best plugs for stock 318? [Re: MoparforLife] #976725
04/20/11 12:45 PM
04/20/11 12:45 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
I used to work at tune up shops, and a number of them offered fuel induction cleaning. Rather than get the engines hot then change plugs, we would tune the car then run the stuff through. I also changed a LOT of plugs and saw new defects and how the old ones held up more than most people.
I prefer Autolite, had too many problems with Champion. NGKs are darn good plugs too.
Bosch platinum if you are going to leave them in for 80K (I don't recommend it on older stuff, but people do it.)
Re: best plugs for stock 318? [Re: RodStRace] #976726
04/20/11 02:10 PM
04/20/11 02:10 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Such as??? Ive never had a problem with them, and I have run them in everything from stock street cars to 8,000rpm race cars.
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Re: best plugs for stock 318? [Re: scratchnfotraction] #976727
04/20/11 04:21 PM
04/20/11 04:21 PM
Me too but I'd say any plug on sale would work fine in a DD 318
Re: best plugs for stock 318? [Re: 69L78Nova] #976728
04/21/11 01:51 AM
04/21/11 01:51 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Uneven gaps from the factory (shoddy QA), easier to foul than other brands in the same situations, and I've had exactly 2 brands of plugs where the porcelain has been broken around the center electrode, sliding down when the plug was held spark end down, sliding back up to normal with wire end down. I've seen 6 plugs brand new broken this way, 2 tune-up masters (made in Eastern Europe) and 4 Champions (at 3 different times). You can say it was due to rough handling or packaging, but I have not seen it on any other plugs. The porcelain also tends break easier when removing.
