Indy heads #976614
04/19/11 10:52 PM
04/19/11 10:52 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
I am thinking about buying a set of ported 360-2 heads and intake for a 420 small block that I plan on building this fall. Right now I am running a 360/380 hp crate motor in my D-50.Do you think these heads would work very well if I put them on my crate motor while I was collecting the parts for the other motor.It would be hard to let the heads just set in the closet for a few months.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Indy heads [Re: D-50] #976615
04/20/11 12:34 AM
04/20/11 12:34 AM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
have a look at the current c.r. and the one it would yield with the -2 heads
Don't forget you would need the matching intake and valve train
Dan
Re: Indy heads [Re: Wedgeman] #976616
04/20/11 05:52 PM
04/20/11 05:52 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
u never know,my bud switched from a set of worked eddy's to a set of 360-1's and dropped a 1/2 sec with no other change then the headers and heads,,on a race motor
Re: Indy heads [Re: D-50] #976617
04/20/11 09:56 PM
04/20/11 09:56 PM
Renton Washington
Triple Threat Offline
Renton Washington
Tough to say, on a race only deal where bottom end doesn't matter too much it might not be too bad. I've thought about trying it as well but never have.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Indy heads [Re: D-50] #976618
04/21/11 02:55 AM
04/21/11 02:55 AM
SoCal
Brian Hafliger Offline
SoCal
They're a great cylinder head but the 210 port might work better depending on your plans...
Brian
Brian Hafliger
Re: Indy heads [Re: Brian Hafliger] #976619
04/21/11 06:59 PM
04/21/11 06:59 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
They are CNC ported 360-2 230cc and ported 360-3 intake.I am buying them from a moparts member.
Re: Indy heads [Re: D-50] #976620
04/23/11 02:17 PM
04/23/11 02:17 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Hi D-50. Looks like a fun truck. I run Indy 360-1s on my car,they are not a quick bolt on for your truck. Different exhaust port, Rocker oiling, push rods,etc. I think you would be better off to wait and put them on your big motor. The Indys do make power but you have to check everything, and don't believe the book specs. Also I would never ever ever ever buy another kit from Indy, heads and intake only. Have fun with it.
"Just a Bracket car dressed up like a streetcar"
