Line X or Rhinoliner as undercoat? #976405
04/19/11 03:01 PM
04/19/11 03:01 PM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
I'm redoing my 69 dart and I have it all blasted and was wondering who has used truck bed liner as an undercoat. I was wanting to paint the underside of this car but i'm going to drive it and was thinking the bed liner would give me sound and heat resistance and would also never chip or peel. Thanks
Re: Line X or Rhinoliner as undercoat? [Re: rck850] #976406
04/19/11 03:10 PM
04/19/11 03:10 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
jrwoodjoe went that route on his Challenger and it turned out really nice.
https://board.moparts.org/ubbthreads/upload2/5348148-undercoat.JPG
Re: Line X or Rhinoliner as undercoat? [Re: rck850] #976407
04/19/11 03:13 PM
04/19/11 03:13 PM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
My current CJ-7 has a roll-on bedliner on the inside and underside of the body tub. Works great, very durable.
My previous CJ-7 had Rhino Liner. Also worked great, but cost alot more. However, it looked neater and cleaner than the roll-on. For a nice street/show car, I'd go with Rhino or Line-X. For someone like me, who beats the snot out of my CJ, the roll-on is plenty good.
Earning every penny of that moderator paycheck.
DBAP
Re: Line X or Rhinoliner as undercoat? [Re: not_a_charger] #976408
04/19/11 03:30 PM
04/19/11 03:30 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Being from a warmer climate I used Hippo Liner.. I sprayed it myself using a Sata undercoating gun.. Looks pretty good IMO..
Re: Line X or Rhinoliner as undercoat? [Re: 1_WILD_RT] #976409
04/19/11 03:46 PM
04/19/11 03:46 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Do any of these come in colors or are you pretty much stuck with black? What about painting over them ... I'd like the finish and protection but I'd also like to have the stuff body color.
Epoxy primer first I assume ???
Re: Line X or Rhinoliner as undercoat? [Re: Stanton] #976410
04/19/11 03:55 PM
04/19/11 03:55 PM
The spray-ons like Rhino and Line-x can be made is lots of colors. I've not seen colors in the do-it-yourself products, but I'm sure they're out there.
DBAP
Re: Line X or Rhinoliner as undercoat? [Re: not_a_charger] #976411
04/19/11 03:59 PM
04/19/11 03:59 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
There are plenty of colored type available... Some are better than others....
Re: Line X or Rhinoliner as undercoat? [Re: 1_WILD_RT] #976412
04/19/11 04:33 PM
04/19/11 04:33 PM
New Hampshire
W
whitemtnelf Offline
whitemtnelf  Offline
W
New Hampshire
I checked with CoolCar undercoating about their product and here's the response (I have no business relationship with them):
"CoolCar does not need a top coat. It is tough and will stand up to the same protection as a bed liner but will also give you insulation from the heat given off by the exhaust system."
Re: Line X or Rhinoliner as undercoat? [Re: burdar] #976413
04/19/11 04:56 PM
04/19/11 04:56 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Thanks for the compliment Darren. U-POL Raptor Liner is color tintable. What I liked about it is that the texture is pretty nice and similar (not exact) to a factory undercoat when sprayed. However, it can be brushed on if you like. Mine was sprayed. I just took a quick snap shot under the trunk pan for you. You can see the texture is pretty "light". My car was coded for undercoat and had undercoat from one end to the other when I got it. I plan on driving it and I wanted something that looked good and was easy to maintain.
65 Barracuda
70 Challenger
Re: Line X or Rhinoliner as undercoat? [Re: jrwoodjoe] #976414
04/19/11 10:41 PM
04/19/11 10:41 PM
None
71rm23 Offline
71rm23  Offline
None
jrwoodjoe...does look really good
Re: Line X or Rhinoliner as undercoat? [Re: 71rm23] #976415
04/20/11 12:23 AM
04/20/11 12:23 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
What's under the U-POL Raptor Liner ??
Re: Line X or Rhinoliner as undercoat? [Re: Stanton] #976416
04/20/11 12:41 AM
04/20/11 12:41 AM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
Well I've been in contact with a local LineX guy and with surface area calculations and pictures he quoted me between $400 and $500 to do the whole underside and wheel wells. seems a lot better then the other local LineX guy who quoted me $2000
Re: Line X or Rhinoliner as undercoat? [Re: Stanton] #976417
04/20/11 12:49 AM
04/20/11 12:49 AM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Etch Primer over bare metal, as specified in the Raptor Liner Technical Data Sheet.
Re: Line X or Rhinoliner as undercoat? [Re: rck850] #976418
04/20/11 07:22 PM
04/20/11 07:22 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
Rhino Linings, of course I'm a dealer. masking and taping takes most of the time to do a spray on bedliner, if you can have it ready to just be sprayed, you might be able to save some money! Surface must be scuffed up and cleaned by a thinner or other product, so if you tell them all they have to do is spray it, you could get a better price!
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
Re: Line X or Rhinoliner as undercoat? [Re: deansrr] #976419
04/28/11 10:11 PM
04/28/11 10:11 PM
eastern,Ky
70RT Charger Offline
eastern,Ky
Line-X has the best texture.If he can do it for $400-$500 you better jump on it like a duck on a june bug but I doubt that he can do it that cheap unless he puts it on there paper thin.Herculiner probably has the best do it yourself bedliner.I sprayed mine on with an undercoating gun.I think I did as good as job as Line-X lol.Save a few bucks and DIY.
