440 Source Stealth heads for 440 #975971
04/18/11 05:48 PM
04/18/11 05:48 PM
IN
scotts Offline OP
scotts  Offline OP
IN
Any body running these heads on there 440? If so Likes and dislikes? Thanks Scott
Re: 440 Source Stealth heads for 440 [Re: scotts] #975972
04/18/11 06:48 PM
04/18/11 06:48 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Have them on my 12.5 440.Its street driven.Been on it going on 4 years and no problems.I did change the springs retainers and keepers.I run a .588 solid cam and 4 speed.I would have had to change those parts on any head I bought.Rocky
Chrysler Firepower
Re: 440 Source Stealth heads for 440 [Re: therocks] #975973
04/18/11 06:56 PM
04/18/11 06:56 PM
California
court9155 Offline
court9155  Offline
California
I have a set here in the garage, same changed springs locks etc but also had to have a step on the back of some of the intake valve seats knocked down and had a little bowl work done as well.
I can take pics if you are on the verge of ordering them.
To do over I would have just bought indys or edelbrocks
Re: 440 Source Stealth heads for 440 [Re: scotts] #975974
04/18/11 09:47 PM
04/18/11 09:47 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
I have bought a set.
They look nice but I noticed the machine work wasnt perfect. The valves seats where not machined perfectly level. If putting a straight edge on the tips of the valves you could see some missalignment.
I had a friend installed a set and they cracked, the had some problems with the castings not being stress relieved and they were a bit crack prone...but I think it was just a bad batch and they already have taken care of that....
Regardless I like the fact that they look stock from the outside...unlike the edelborcks.
I guess they are a good head for the right application. Just blueprint the machining...
Re: 440 Source Stealth heads for 440 [Re: scotts] #975975
04/18/11 09:58 PM
04/18/11 09:58 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Do a search on here, the topic has been covered to death.
Short answer, generally good for intended purpose as an inexpensive replacement head that looks stock.
Re: 440 Source Stealth heads for 440 [Re: scotts] #975976
04/18/11 11:52 PM
04/18/11 11:52 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I changed the springs,locks and reatiners,but I'm using a different cam and racing. I would buy another set with no problem.
Nautilus Racing-
Re: 440 Source Stealth heads for 440 [Re: Chris2581] #975977
04/19/11 02:31 AM
04/19/11 02:31 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I run a set of them straight out of the box. No problems.
Re: 440 Source Stealth heads for 440 [Re: DaytonaTurbo] #975978
04/19/11 07:31 AM
04/19/11 07:31 AM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Same here.
Re: 440 Source Stealth heads for 440 [Re: ireland383] #975979
04/19/11 11:44 AM
04/19/11 11:44 AM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
Changed the locks and retainers (10º), on an 11:1 550hp 440. Couldn't be happier.
Re: 440 Source Stealth heads for 440 [Re: scotts] #975980
04/19/11 11:59 AM
04/19/11 11:59 AM
California
court9155 Offline
court9155  Offline
California
Id be happy to post pics of the stealth heads I have here.
Dan
67 charger
Re: 440 Source Stealth heads for 440 [Re: court9155] #975981
04/19/11 05:24 PM
04/19/11 05:24 PM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
I got them on my coronet. I changed out retainers and that was it. I have had no issues.
Mike
1969 Dodge Dart Swinger
