Upper Ball Joint #975675
04/18/11 12:18 PM
04/18/11 12:18 PM
Columbia, Missouri
dtedler Offline OP
dtedler  Offline OP
Columbia, Missouri
I've got an upper ball joint that I need to replace on a 73 Challenger. I'm here at work and forgot to measure the socket that I need. Does anyone have an idea as to the size of the socket required. I'm going to raid my buddies tool chest after work.
Thanks -
Re: Upper Ball Joint [Re: dtedler] #975676
04/18/11 12:35 PM
04/18/11 12:35 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
the sockets are specially made for those ball joints.
Tony
70 AARCuda Vitamin C
Re: Upper Ball Joint [Re: 70AARcuda] #975677
04/18/11 01:25 PM
04/18/11 01:25 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Yep , in a pinch a pipe wrench will work , it's basically a 2 sided cap with rounded corners .
Re: Upper Ball Joint [Re: dtedler] #975678
04/18/11 03:54 PM
04/18/11 03:54 PM
IMGTX Offline
IMGTX  Offline
Re: Upper Ball Joint [Re: JohnRR] #975679
04/18/11 05:04 PM
04/18/11 05:04 PM
yes w care & I would suggest slightly unscrewing the castellated nut on the bottom then tapping on the side of the spindle to break it (the tapered stud) loose letting the tension do the work for you then back on top breaking the UBJ loose while the arm is still on the vehicle. Thought they (UCA's) were stouter than that but can bend one R&R ing the UBJ in a vise then it's too wide/narrow when you go to set the bushing ends back into the frame
