Head O Rings or Head Gaskets #974006
04/15/11 10:44 PM
04/15/11 10:44 PM
usa
9
90ram Offline OP
90ram  Offline OP
usa
I'm getting closer to Finishing My 572 with B-1MC Heads, I have been told I should O-Ring the Heads. Anybody else running the same combo with just Head Gaskets or Cometics. I heard the Cometics where Good. But a couple Engine Shops I know quit using them lately because of them leaking.. Will I be a fool if I dont O-Ring the Heads?
Re: Head O Rings or Head Gaskets [Re: 90ram] #974007
04/16/11 12:15 AM
04/16/11 12:15 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Cometics have worked fine up to 15-1 compression for me. I haven't o-ringed a motor for years. Let's see what others say.
Re: Head O Rings or Head Gaskets [Re: 90ram] #974008
04/16/11 12:30 AM
04/16/11 12:30 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I was going to run just Cometics with my B-1m/c at 15:1
but sold my stuff
Re: Head O Rings or Head Gaskets [Re: MR_P_BODY] #974009
04/16/11 11:34 AM
04/16/11 11:34 AM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
use the Cometics, either copper coat them or just use a little hi temp RTV around the water ports.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Head O Rings or Head Gaskets [Re: 90ram] #974010
04/16/11 05:19 PM
04/16/11 05:19 PM
springfield,il
O
orangeduster Offline
O
springfield,il
o-ring and be done ! my
Re: Head O Rings or Head Gaskets [Re: orangeduster] #974011
04/16/11 05:25 PM
04/16/11 05:25 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
I went with the sce titans this time around. Copper with oring built in.
Re: Head O Rings or Head Gaskets [Re: mac56] #974012
04/16/11 08:26 PM
04/16/11 08:26 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
I used copper hg, with o ring block and reciever groove in the head. But I did this yrs ago. I am not sure it needed to be done, but the was 300 bucks. 14.85 -1 comp
Re: Head O Rings or Head Gaskets [Re: Mopar-Al] #974013
04/16/11 08:51 PM
04/16/11 08:51 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
If you have the tools to do it yourself, go for it! I Did the O-rings in the block and receiver in the head on my two engines. Then I made my own copper gaskets with a water cutter and a CAD.
Those Titans are not CHEAP and after a buying a few you will wish you went with the o-rings. Just figure your costs and see if the o-ringing is worth it or not financially.
Re: Head O Rings or Head Gaskets [Re: 90ram] #974014
04/16/11 11:31 PM
04/16/11 11:31 PM
Winterpeg, Canada
hvyweight Offline
hvyweight  Offline
Winterpeg, Canada
I can tell you from experience (last month) that if you run o rings in the heads with no receiver groove in the block you may have issues. I could not run receiver grooves in my alum world block because the outer diameter of the sleeve was within .020 of the alum block. I just went to Cometics and should be putting back together shortly. My comp is 14.68. Will be spraying a fairly big shor of nitrous.
Re: Head O Rings or Head Gaskets [Re: 90ram] #974015
04/16/11 11:33 PM
04/16/11 11:33 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
My o-rings only stick out about .006 out of the block, my heads don't have a receiver groove. I've fought leaks for years, I CANNOT get these copper gaskets to seal and cannot get the darn o-rings out of the block! I run less than 12:1 compression and will never run o-rings again, I'll just run regular composition head gaskets which I've NEVER had a problem with.
Re: Head O Rings or Head Gaskets [Re: ProSport] #974016
04/16/11 11:39 PM
04/16/11 11:39 PM
Winterpeg, Canada
hvyweight Offline
hvyweight  Offline
Winterpeg, Canada
What thickness of head gasket? If I remember right I think a 040 needs .012 protruding?
Re: Head O Rings or Head Gaskets [Re: hvyweight] #974017
04/16/11 11:50 PM
04/16/11 11:50 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I've tried 40's and 32's, the combustion chamber works fine, but the water leaks. I've even scotch brited the copper and used Yamabond4 and one side still leaked. Ended up throwing a felpro 1009 on that side for the last 2 races of the year and it worked great even though the o-ring intersected the head gasket in several spots.
I may loose some compression and try the thicker felpro 1039 with larger bore if it will go around my o-rings and still hold the o-rings in place, don't want them coming loose and going through the motor or valves.
Re: Head O Rings or Head Gaskets [Re: ProSport] #974018
04/17/11 10:29 PM
04/17/11 10:29 PM
usa
9
90ram Offline OP
90ram  Offline OP
usa
Re: Head O Rings or Head Gaskets [Re: 90ram] #974019
04/17/11 11:17 PM
04/17/11 11:17 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Ran O-rings for years. .041" diameter wire. Then cut the tool to only cut .040 wide so the wire will stay in place. Make the groove .029 deep. This leaves you with .012 out of the block. Spray a tack coat of copper coat and then a heavy coat. When you still have blowby. Cut a .041 .010 deep reciever in the head. This will hold the fire where it belongs.
I later went to cometics and had great success that way too. They do seem to be loosing their quality. I need to buy a new set.
If you are leaking you are doing something wrong.
Leon
