High Volume or High Pressure, oil pump...
#973995
04/15/11 10:32 PM
04/15/11 10:32 PM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
Looking at recommendations for replacement oil pump. The advice I had is from back in the day and was to use a high volume. Engine is a 440, 0.030 over. 12:1 CR with TRW pistons. Main bearings are half groove. Cam tops out at 6000 rpm. Have 8 quart pan for it. I have had high volume pumps on engines in the past with no ill effects. I am just not sure what the current thinking is now days. Any recommendations on a pump?
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
Re: High Volume or High Pressure, oil pump...
[Re: 440forPOWER]
#974003
04/16/11 01:17 PM
04/16/11 01:17 PM
RapidRobert
Morning Tim, alot of variables go into it, bottom line is to use the thinnest oil/std vol & psi pump that will maintain a safe PSI for your eng/app. Idle can actually b low if it jumps up right when you goose it and on the high end for a dragger 8-10 psi per 1000 rpm is a safe ballpark figure. I'd b way more concerned w doing the proper internal mods rather than what the gauge shows at it's highest point when it exits the filter & goes up to the sending unit
[Re: 440forPOWER]
#974005
04/16/11 03:38 PM
04/16/11 03:38 PM
Posts: 4,314 Prospect, PA
BSB67
Prospect, PA
Just curious, would a standard pump be ok for full groove main bearings? Thanks
Generally yes with typical clearances and oiling.
