EDM Lifters #973561
04/15/11 12:49 AM
04/15/11 12:49 AM
Amarillo, Texas
red70duster Offline OP
Amarillo, Texas
I purchased some edm lifters to use with my new Ultradyne cam. THey were the barbell looking type and I lost all oil pressure because they were uncovering on the downstroke. So my machinist ordered me a set of Howards Cams edm lifters. Got them in today and they are too tall! I thought all small block solid lifters were the same length. The seat where the pushrod seats is higher up in the body of the lifter as well. I would have to have pushrods at least .07 in shorter. Has anyone out there run into this? I'll call Howards Cams tomorrow but I was curious and hoped I might get an answer tonight.
Re: EDM Lifters [Re: red70duster] #973562
04/15/11 12:53 AM
04/15/11 12:53 AM
IN
ahy Offline
ahy  Offline
IN
I don't run Howards but I do understand they are taller and require shorter pushrods. A couple days from Smith Bros.
Re: EDM Lifters [Re: ahy] #973563
04/15/11 05:50 AM
04/15/11 05:50 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Yep....it is well known that the howards lifters require a shorter pushrod. I run them in my BB and saved some money because I was switching from a Hyd cam to a solid and my old hyd pushrods ended up being the perfect height with the howard solid lifters.
Re: EDM Lifters [Re: Quicksilver440] #973564
04/15/11 08:30 AM
04/15/11 08:30 AM
The Great White North
RAMM Offline
RAMM  Offline
Very common. EDM's barbell styles? Why? J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: EDM Lifters [Re: red70duster] #973565
04/15/11 09:44 AM
04/15/11 09:44 AM
NC
440Jim Offline
440Jim  Offline
NC
Sorry to say, but both of your issues are well known to Mopar builders...
I posted about the Howards EDM lifter pushrod height years ago. I run them, and like them. But the pushrod needed is shorter than the old MP solid lifters.
And those barbells...
Re: EDM Lifters [Re: red70duster] #973566
04/15/11 09:55 AM
04/15/11 09:55 AM
Amarillo, Texas
Amarillo, Texas
Thanks for your replies. Guess my machinist should have known this. Now I need to decide if I should change lifters or get new pushrods.
Re: EDM Lifters [Re: ahy] #973567
04/15/11 10:03 AM
04/15/11 10:03 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
.....or quicker!!! I have ordered from Smith when they had to make them up before shipping and recieved them the next morning!!
The 3 hour time difference really helps us East coast people. Ordered at 11:30 AM Eastern time and got them before 10:00AM the next morning with over-night shipping. The total cost was cheaper than Comp push rods would have been buying locally.
If you like drag racing, support your local track.
Re: EDM Lifters [Re: CHAPPER] #973568
04/15/11 11:28 AM
04/15/11 11:28 AM
Indiana
Cuda_Mike Offline
Cuda_Mike  Offline
Indiana
Bullet talked me out of using the edm's on my new UD grind, and sent me the "barbell's", after posting here concerning the possible oiling issues I called them and they encouraged me to send those back and sent me conventional solids. They told me the edm's are the same lifters with the oiling hole. They probably have edm's for your engine, that aren't the barbell style.
Re: EDM Lifters [Re: Cuda_Mike] #973569
04/15/11 11:40 AM
04/15/11 11:40 AM
Indiana
Cuda_Mike Offline
Cuda_Mike  Offline
Indiana
The conventional lifter, both available in edm.
