Re: Sorry but, anyone use the 440 source bronze gear?
[Re: 440forPOWER]
#973253
04/15/11 11:45 AM
04/15/11 11:45 AM
Posts: 2,826 NY usa
540challenger
NY usa
Ok I'll give it a try. Mine is a street hydraulic roller so thats why I tried it here. Thanks
If it is a street roller are you sure you need a bronze gear there alot of rollers out there that don't need a bronze gear now. Check the cam specs it will tell you if you need one.
[Re: 540challenger]
#973254
04/15/11 11:58 AM
04/15/11 11:58 AM
Posts: 4,799 ILL
MLR426
ILL
It depends on what the camshaft is made of, steel shaft must have the bronze gear, cast shafts do not.
logan426
[Re: 440forPOWER]
#973256
04/15/11 12:39 PM
04/15/11 12:39 PM
Posts: 2,826 NY usa
540challenger
NY usa
Yes it's a comp cams roller and it is a billet core. http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=1443&sb=2
that seems like a mild roller i couldn't find where it says what core they use or what gear is required, I know the paper catalog used to say what gear you needed. Are you sure that is a billet core might want to call them there website info stinks i can DL new products catalog but not there standard catalog todouble check sorry for derailing this thread...
[Re: 440forPOWER]
#973258
04/15/11 01:03 PM
04/15/11 01:03 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Somethign to think about too... The bronze is also known to wear fast in some instances. I've personally seen one engine that eats them in 5K miles, and another that has 20K and is barely worn. Those were both MP oil pump drives but just so you know some engines just eat them much faster.
[Re: 440forPOWER]
#973260
04/15/11 01:19 PM
04/15/11 01:19 PM
moper
Columbia, CT
I believe all Crane's hydraulic rollers come with a cast iron gear too. No bronze needed.
[Re: TooMany62s]
#973262
04/15/11 08:58 PM
04/15/11 08:58 PM
moper
Columbia, CT
I'm using a Crane Hydraulic Roller. They advised using a bronze distributor gear and bronze tip fuel pump pushrod.
You're right... I just checked. Big blocks do not have the iron gear. The small blocks all can use a standard drive.
