Sorry but, anyone use the 440 source bronze gear? #973250
04/14/11 09:48 PM
04/14/11 09:48 PM
Lincoln NE
440forPOWER Offline OP
super gas
super gas
Lincoln NE
Hello, sorry to start another 440 source post. But I was curious if anyone has used the 440source bronze distributor drive. Any problems? The main thing I wonder if it's a hardened shaft and how well it's done if it's from china? Thanks
Re: Sorry but, anyone use the 440 source bronze gear? [Re: 440forPOWER] #973251
04/15/11 10:22 AM
04/15/11 10:22 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
you might want to ask this in the race section
Re: Sorry but, anyone use the 440 source bronze gear? [Re: bonefish] #973252
04/15/11 11:11 AM
04/15/11 11:11 AM
Lincoln NE
super gas
super gas
Lincoln NE
Ok I'll give it a try. Mine is a street hydraulic roller so thats why I tried it here. Thanks
Re: Sorry but, anyone use the 440 source bronze gear? [Re: 440forPOWER] #973253
04/15/11 11:45 AM
04/15/11 11:45 AM
NY usa
540challenger Offline
NY usa
If it is a street roller are you sure you need a bronze gear there alot of rollers out there that don't need a bronze gear now.
Check the cam specs it will tell you if you need one.
Re: Sorry but, anyone use the 440 source bronze gear? [Re: 540challenger] #973254
04/15/11 11:58 AM
04/15/11 11:58 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
It depends on what the camshaft is made of, steel shaft must have the bronze gear, cast shafts do not.
logan426
Re: Sorry but, anyone use the 440 source bronze gear? [Re: MLR426] #973255
04/15/11 12:14 PM
04/15/11 12:14 PM
Lincoln NE
super gas
super gas
Lincoln NE
Yes it's a comp cams roller and it is a billet core. http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=1443&sb=2
Re: Sorry but, anyone use the 440 source bronze gear? [Re: 440forPOWER] #973256
04/15/11 12:39 PM
04/15/11 12:39 PM
NY usa
NY usa
that seems like a mild roller i couldn't find where it says what core they use or what gear is required, I know the paper catalog used to say what gear you needed. Are you sure that is a billet core might want to call them there website info stinks i can DL new products catalog but not there standard catalog todouble check sorry for derailing this thread...
Re: Sorry but, anyone use the 440 source bronze gear? [Re: 540challenger] #973257
04/15/11 12:49 PM
04/15/11 12:49 PM
Lincoln NE
super gas
super gas
Lincoln NE
Yeah it's a mild roller. The sheet that came with the cam says to use a bronze shaft.
Re: Sorry but, anyone use the 440 source bronze gear? [Re: 440forPOWER] #973258
04/15/11 01:03 PM
04/15/11 01:03 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Somethign to think about too... The bronze is also known to wear fast in some instances. I've personally seen one engine that eats them in 5K miles, and another that has 20K and is barely worn. Those were both MP oil pump drives but just so you know some engines just eat them much faster.
Re: Sorry but, anyone use the 440 source bronze gear? [Re: moper] #973259
04/15/11 01:11 PM
04/15/11 01:11 PM
Lincoln NE
super gas
super gas
Lincoln NE
I'm hoping mine is more like the 20k motor. I almost bought the Hughes cam as they are on a cast core. But I heard great things about the comp cams hydraulic rollers. I guess I'll see.
Re: Sorry but, anyone use the 440 source bronze gear? [Re: 440forPOWER] #973260
04/15/11 01:19 PM
04/15/11 01:19 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I believe all Crane's hydraulic rollers come with a cast iron gear too. No bronze needed.
Re: Sorry but, anyone use the 440 source bronze gear? [Re: moper] #973261
04/15/11 02:37 PM
04/15/11 02:37 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
I'm using a Crane Hydraulic Roller. They advised using a bronze distributor gear and bronze tip fuel pump pushrod.
Re: Sorry but, anyone use the 440 source bronze gear? [Re: TooMany62s] #973262
04/15/11 08:58 PM
04/15/11 08:58 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
You're right... I just checked. Big blocks do not have the iron gear. The small blocks all can use a standard drive.
