putting the disc brakes on the 8 3/4 #972970
04/14/11 12:07 AM
04/14/11 12:07 AM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
ok i got all the parts to put rear disc brakes on the challenger the caliper bracket needs welded on but before that happens i need to know wich way to take the slack out of the caliper has 2 stainless allen head pins the caliper can slid across on. Do i shove the piston up against the rotor or the back all the way up against the rotor and let piston come out and take slack out?
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: putting the disc brakes on the 8 3/4 [Re: toplescuda] #972971
04/14/11 02:30 AM
04/14/11 02:30 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
when I did a disc conversion on a 9 1/4 I put a piece of cereal box cardboard between the pads and the rotor. This allows a small space to install new pads in the future. I then used compressed air to clamp and basicly center everything... remember on a 8 3/4 there is a inner seal that will need to be removed before welding....
I am truckless..
Re: putting the disc brakes on the 8 3/4 [Re: 340SHORTY] #972972
04/14/11 03:41 AM
04/14/11 03:41 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
rotors are new caliper is new,but there is at least 1/4 inch gap /slack dont have a way of useing compressed air
1971 charger
Re: putting the disc brakes on the 8 3/4 [Re: toplescuda] #972973
04/14/11 06:36 AM
04/14/11 06:36 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
the caliper with the pads loaded into it, should be centered over the rotor with equal gaps front and rear between the pad's surface and the rotor's surface, I would locate/shim the caliper to position in it's static mode, do not charge the caliper
Re: putting the disc brakes on the 8 3/4 [Re: DAYCLONA] #972974
04/14/11 07:28 AM
04/14/11 07:28 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
so your saying to put the pins halfway through travel also then set to centered on rotor? ralph
1971 charger
