putting the disc brakes on the 8 3/4
#972970
04/14/11 12:07 AM
04/14/11 12:07 AM
Posts: 8,852 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
ok i got all the parts to put rear disc brakes on the challenger the caliper bracket needs welded on but before that happens i need to know wich way to take the slack out of the caliper has 2 stainless allen head pins the caliper can slid across on. Do i shove the piston up against the rotor or the back all the way up against the rotor and let piston come out and take slack out?
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: putting the disc brakes on the 8 3/4
[Re: toplescuda]
#972971
04/14/11 02:30 AM
04/14/11 02:30 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
when I did a disc conversion on a 9 1/4 I put a piece of cereal box cardboard between the pads and the rotor. This allows a small space to install new pads in the future. I then used compressed air to clamp and basicly center everything... remember on a 8 3/4 there is a inner seal that will need to be removed before welding....
I am truckless..
[Re: 340SHORTY]
#972972
04/14/11 03:41 AM
04/14/11 03:41 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
rotors are new caliper is new,but there is at least 1/4 inch gap /slack dont have a way of useing compressed air
[Re: DAYCLONA]
#972974
04/14/11 07:28 AM
04/14/11 07:28 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
so your saying to put the pins halfway through travel also then set to centered on rotor? ralph
