Powermaster Alternator Question...
#972877
04/13/11 09:53 PM
04/13/11 09:53 PM
Posts: 252 L.A., CA
plysat
L.A., CA
I'm planning on replacing the stock alternator in my '68 Satellite with a powermaster pn175191, and modifying the charging system wiring as seen here: http://home.roadrunner.com/~raffica/electrical.htmSeems pretty straightforward, but my question concerns the alernator. While it looks like the it should just bolt right in, I noticed in the specs that it's internally regulated. I assume that means I can't just wire it up to the stock harness? Do I need to bypass the stock regulator? and if so... How? Thanks in advance!
Re: Powermaster Alternator Question...
[Re: plysat]
#972880
04/14/11 12:07 AM
04/14/11 12:07 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
the internal regulator on pn175191 is fairly non thruth. They are MOUNTED ON regulators where they are not switched on from ign switch, really from stator signa ( that's what makes them posible to be ONE WIRE ), but brushes actually wired the same than stock, so you can live with it or remove and wire it like stock lates units
[Re: NachoRT74]
#972881
04/14/11 12:11 AM
04/14/11 12:11 AM
NachoRT74
Valencia, España
I never have seen personally those, but by pics and allways show this kind of reg mounted on chassis: thats what makes them to work like being ONE WIRE
[Re: 70AARcuda]
#972883
04/14/11 10:30 AM
04/14/11 10:30 AM
NachoRT74
Valencia, España
yeap thats it, I'm just only shown to let him know what are we talking about. Not saying is the same piece ( what mostly sure it is ) but sure same kind
[Re: plysat]
#972885
04/14/11 04:58 PM
04/14/11 04:58 PM
Posts: 5,890 Athens, Greece
Pyper70
Athens, Greece
My Powermaster 120amp was a single wire. I ran an 8gauge wire from the pole of the alternator to the battery. Took 1400rpm to actually turn it on similar to a GM alternator. The only thing to watch out for is the back post where the 8 gauge cable fits on. I would stomp on it from a red light and the belt would clench causing the alternator to flex and ground out on my cylinder head. Removing the three housing studs and rotating the assembly 90 degrees solved it.
I dont have the car anymore. I run a Delco Remy on my 440. Two wires. Cheaper too
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: RapidRobert]
#972887
04/14/11 09:06 PM
04/14/11 09:06 PM
Posts: 252 L.A., CA
plysat
L.A., CA
Thanks guys... now I'm totally confused lol
Oh It'll get worse .
Great! Looking forward to it. Thanks again...
