Eddy 1406 bolt spacing C to C & throttle plate bore dia #972826
04/13/11 08:22 PM
04/13/11 08:22 PM
RapidRobert Offline OP
Does anyone know these dimentions. I am wanting to purchase an antique manifold if this carb will fit it. I was given ~4&1/4 wide C to C and ~5&1/2" C to C front to rear on the intake bolt holes. No info on the manifold bore holes. Thank you for your time.
Re: Eddy 1406 bolt spacing C to C & throttle plate bore dia [Re: RapidRobert] #972827
04/13/11 10:28 PM
04/13/11 10:28 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
bolt spacing is standard square bore...if you have a square bore holley, measure the bolt spacing....
2017 Grand Cherokee Overland
Re: Eddy 1406 bolt spacing C to C & throttle plate bore dia [Re: patrick] #972828
04/13/11 10:34 PM
04/13/11 10:34 PM
It's a '58 dual quad BB intake, wondering if Eddy 1406 carbs will fit. Bolt pattern and throttle bores. Not sure what it had OE but assuming AFB
Re: Eddy 1406 bolt spacing C to C & throttle plate bore dia [Re: RapidRobert] #972829
04/13/11 10:48 PM
04/13/11 10:48 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
The early AFB pattern was/is narrower than the Holley squarebore pattern.Later manifolds (aftermarket) are usually drilled with both patterns.My CH-28 dual 4 barrel intake has the narrow flange pattern only.I can get a measurement in the morning if you want,or try Edelbrock's site maybe?
Keith
Re: Eddy 1406 bolt spacing C to C & throttle plate bore dia [Re: Dunnuck Racing] #972830
04/13/11 10:51 PM
04/13/11 10:51 PM
Kieth let me try Edelbrocks site real quick. EDIT what carbs are you running on the ch-28? AFB's? or did you use adapters & something else MORE EDIT nothing on their site, kieth I'll check in the AM thank you for the offer to check!
Re: Eddy 1406 bolt spacing C to C & throttle plate bore dia [Re: RapidRobert] #972831
04/14/11 10:22 AM
04/14/11 10:22 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Robert I think the 58 might have used a WCFB , or is that a WFCB ??? Anyway not sure how it's pattern compares to the AFB. The Edlebrock carbs come drilled for both the early AFB pattern and the later squarebore. I can get some measurements later if no one steps up.
Re: Eddy 1406 bolt spacing C to C & throttle plate bore dia [Re: JohnRR] #972832
04/14/11 11:13 AM
04/14/11 11:13 AM
Northern Indiana
Northern Indiana
Okay,the pattern on this is 4 1/4 wide by 5 5/8 front to back.I would bet that is what he has also if you get him to remeasure it.
This is the inner(small) bolt pattern on the Edelbrock Performer carbs also.
I have a pair of 600 Edelbrocks on this intake.
They are drilled with this pattern,and the Holley pattern(called squarebore,but not actually square).
Picture added
Keith
Re: Eddy 1406 bolt spacing C to C & throttle plate bore dia [Re: Dunnuck Racing] #972833
04/14/11 04:41 PM
04/14/11 04:41 PM
Thanks double R and Kieth for the help/info. It's on it's way
