Eddy 1406 bolt spacing C to C & throttle plate bore dia
#972826
04/13/11 08:22 PM
04/13/11 08:22 PM
RapidRobert
Does anyone know these dimentions. I am wanting to purchase an antique manifold if this carb will fit it. I was given ~4&1/4 wide C to C and ~5&1/2" C to C front to rear on the intake bolt holes. No info on the manifold bore holes. Thank you for your time.
Re: Eddy 1406 bolt spacing C to C & throttle plate bore dia
[Re: RapidRobert]
#972827
04/13/11 10:28 PM
04/13/11 10:28 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
bolt spacing is standard square bore...if you have a square bore holley, measure the bolt spacing....
[Re: patrick]
#972828
04/13/11 10:34 PM
04/13/11 10:34 PM
RapidRobert
It's a '58 dual quad BB intake, wondering if Eddy 1406 carbs will fit. Bolt pattern and throttle bores. Not sure what it had OE but assuming AFB
[Re: Dunnuck Racing]
#972830
04/13/11 10:51 PM
04/13/11 10:51 PM
RapidRobert
Kieth let me try Edelbrocks site real quick. EDIT what carbs are you running on the ch-28? AFB's? or did you use adapters & something else MORE EDIT nothing on their site, kieth I'll check in the AM thank you for the offer to check!
[Re: RapidRobert]
#972831
04/14/11 10:22 AM
04/14/11 10:22 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Robert I think the 58 might have used a WCFB , or is that a WFCB ??? Anyway not sure how it's pattern compares to the AFB. The Edlebrock carbs come drilled for both the early AFB pattern and the later squarebore. I can get some measurements later if no one steps up.
[Re: JohnRR]
#972832
04/14/11 11:13 AM
04/14/11 11:13 AM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
Okay,the pattern on this is 4 1/4 wide by 5 5/8 front to back.I would bet that is what he has also if you get him to remeasure it. This is the inner(small) bolt pattern on the Edelbrock Performer carbs also. I have a pair of 600 Edelbrocks on this intake. They are drilled with this pattern,and the Holley pattern(called squarebore,but not actually square). Picture added Keith
#972833
04/14/11 04:41 PM
04/14/11 04:41 PM
RapidRobert
Thanks double R and Kieth for the help/info. It's on it's way
