What flex plate to use? #972737
04/13/11 06:01 PM
04/13/11 06:01 PM
moparman374 Offline OP
I have a 1973 340 with a cast crankshaft that is externally balanced and I have a neutral balanced torque converter.
I have been told that B&M and TCI sell flexplates to use an externally balanced engine with a neutral balanced torque converter.
The bolt pattern on the torque converter I have is 10" diagonally.
Does anyone know what part numbers do I need?
Note: I also know that cast crank 340s and 360s were balanced differently although they were both externally balanced. As a result the torque converters are not interchangable, nor are the "adapter" flexplates.
Any help is appreciated
Thanks a Lot!
Re: What flex plate to use? [Re: moparman374] #972738
04/13/11 06:06 PM
04/13/11 06:06 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
This was just talked about recently , but I can't remember what engine , it was a smallblock though . If the B+M flex plate is still available it has all the needed patterns on it .
Re: What flex plate to use? [Re: JohnRR] #972739
04/13/11 06:51 PM
04/13/11 06:51 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Just bought a 360 one from Mancini at MATS.
They should be able to set you up no problem!
It's in the back of the truck if you really need a part number, but I'd call and ask.
Re: What flex plate to use? [Re: moparman374] #972740
04/13/11 07:21 PM
04/13/11 07:21 PM
WI, USA
67dodge67 Offline
mopar addict
67dodge67  Offline
mopar addict
WI, USA
Thanks a Lot!
Contact John Cope at Cope Racing Trans and talk to him. He set me up without any issues at all. He's a member on here as well.... his work and knowledge is recommended on here many times over.
Re: What flex plate to use? [Re: 67dodge67] #972741
04/13/11 08:18 PM
04/13/11 08:18 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
http://www.summitracing.com/parts/BMM-10235/
this is the flexplate for an external balanced 73 340 with a 727.......
a neutral balanced converter can be used with any externally balanced engine as long as the CORRECT flexplate is used....
and yes...the 340 and 360 are externally balanced differently...the 340 required more weight on the converter or flexplate
Tony
70 AARCuda Vitamin C
