Best way to remove bug poop/water stains from paint?
#972603
04/13/11 03:53 PM
04/13/11 03:53 PM
Posts: 4,808 Castlegar, BC, Canada
That AMC Guy
Still struggling to remove these very faint stains from the paint of my Javelin. They're mostly on the fenders and roof but oddly, not on the hood. They look like water stains but might be River Moth excrement (we get TONS of those buggers around in the summer).
I recently bought a buffer and tried Meguires Fine cut polish. It helped a little and certainly made the paint look better, but if you look into the reflections on the car, I can still see the stains.
Should I step up to a medium cut and try again? The car was redone in base/clear about 10 years ago.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
Re: Best way to remove bug poop/water stains from paint?
[Re: bigsbigelow]
#972605
04/13/11 05:04 PM
04/13/11 05:04 PM
Posts: 1,144 wellington ohio
68-scatpack-rt
In thin ice
In thin ice
wellington ohio
clay bar. make sure you get the fine cut one and a quality one as well.
unions....the folks who brought you the weekend!
[Re: AdamR]
#972610
04/14/11 02:57 AM
04/14/11 02:57 AM
That AMC Guy
Its etched into the paint. You will probably need to compound and or wet sand. Im using Mequaires 205 and 105, Use the compound with a yellow pad @ 1400 rpms, The polish with a yellow pad @ 1200s, then with a black pad @ 900 rpms.
Does speed matter that much? My buffer doesn't have an adjustable speed. It does 3,200 rpm unloaded. I'll admit, I'm a real pansy when it comes to wet-sanding. I've never done it before and I'm really afraid to do it.
