Best way to remove bug poop/water stains from paint? #972603
04/13/11 03:53 PM
04/13/11 03:53 PM
Castlegar, BC, Canada
That AMC Guy Offline OP
Still struggling to remove these very faint stains from the paint of my Javelin. They're mostly on the fenders and roof but oddly, not on the hood. They look like water stains but might be River Moth excrement (we get TONS of those buggers around in the summer).
I recently bought a buffer and tried Meguires Fine cut polish. It helped a little and certainly made the paint look better, but if you look into the reflections on the car, I can still see the stains.
Should I step up to a medium cut and try again? The car was redone in base/clear about 10 years ago.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
Re: Best way to remove bug poop/water stains from paint? [Re: That AMC Guy] #972604
04/13/11 04:52 PM
04/13/11 04:52 PM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
Try Mequires medium cut cleaner wax. Took a lot over spray off my car with little effort.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: Best way to remove bug poop/water stains from paint? [Re: bigsbigelow] #972605
04/13/11 05:04 PM
04/13/11 05:04 PM
wellington ohio
68-scatpack-rt Offline
In thin ice
In thin ice
wellington ohio
clay bar. make sure you get the fine cut one and a quality one as well.
unions....the folks who brought you the weekend!
Re: Best way to remove bug poop/water stains from paint? [Re: 68-scatpack-rt] #972606
04/13/11 05:16 PM
04/13/11 05:16 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Wetsand and rebuff a small spot.
Re: Best way to remove bug poop/water stains from paint? [Re: That AMC Guy] #972607
04/13/11 05:17 PM
04/13/11 05:17 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
turtle wax Bug and tar remover Canadian tire or most auto stores.
http://www.canadiantire.ca/AST/browse/4/...2BRemover.jsp?l
http://www.turtlewax.com/main.taf?p=2,1,4,11
meguir's has some too but I can only personally speak for the turtle was helps with rubber on quarters too
http://www.meguiarsdirect.com/detail/MEG+G10716
Re: Best way to remove bug poop/water stains from paint? [Re: Dodgem] #972608
04/13/11 07:10 PM
04/13/11 07:10 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Its etched into the paint. You will probably need to compound and or wet sand. Im using Mequaires 205 and 105, Use the compound with a yellow pad @ 1400 rpms, The polish with a yellow pad @ 1200s, then with a black pad @ 900 rpms.
Top the paint off with a good sealant then at least 24hrs after removing the sealant wax it.
Re: Best way to remove bug poop/water stains from paint? [Re: AdamR] #972609
04/13/11 11:56 PM
04/13/11 11:56 PM
Jacksonville Florida
elitecustombody Offline
I agree
Re: Best way to remove bug poop/water stains from paint? [Re: AdamR] #972610
04/14/11 02:57 AM
04/14/11 02:57 AM
Does speed matter that much? My buffer doesn't have an adjustable speed. It does 3,200 rpm unloaded. I'll admit, I'm a real pansy when it comes to wet-sanding. I've never done it before and I'm really afraid to do it.
Re: Best way to remove bug poop/water stains from paint? [Re: That AMC Guy] #972611
04/14/11 08:03 AM
04/14/11 08:03 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Yes speed matters. To much speed and compound is a ruined paint job waiting to happen. Find a good detail or body shop.
