Daughters 01 neon not shifting like it should? #972157
04/12/11 07:47 PM
04/12/11 07:47 PM
Northeast, Alpine, NY
9
9 Sec Phill Offline OP
On a road near you
On a road near you
9
My girl has a 01 neon that is not going from 1st into 2cnd like it should, What would cause this? Not familiar with front wheel drive stuff, any help would be great...thanks
Re: Daughters 01 neon not shifting like it should? [Re: 9 Sec Phill] #972158
04/12/11 08:01 PM
04/12/11 08:01 PM
MINNESOTA
BRONZEBEE Offline
BRONZEBEE  Offline
MINNESOTA
Check fluid level first.If its a 3 speed check the linkage from transmission to throttle body,likes to stick.If its a 4 speed scan it.
Re: Daughters 01 neon not shifting like it should? [Re: BRONZEBEE] #972159
04/12/11 09:53 PM
04/12/11 09:53 PM
9
On a road near you
On a road near you
9
kick down cable felt like it was ok. scanned it but no codes.
Re: Daughters 01 neon not shifting like it should? [Re: 9 Sec Phill] #972160
04/12/11 09:55 PM
04/12/11 09:55 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Clogged filter? How long since it was adjusted/filter/fluid changed?
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Daughters 01 neon not shifting like it should? [Re: amxautox] #972161
04/12/11 10:06 PM
04/12/11 10:06 PM
9
On a road near you
On a road near you
9
just serviced the trans about 2 months ago, flushed the trans because the cooler line broke in the rad and filled the trans with cooland and the rad with ATF. New rad and flushed the trans with new filter and fluid and its been fine till now. Checked the stick first and all is fine there, fluid dosnt smell burnt. I just dont know the front wheel drive trannys.
Re: Daughters 01 neon not shifting like it should? [Re: 9 Sec Phill] #972162
04/12/11 10:14 PM
04/12/11 10:14 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
It's virtually the same as any old Torqueflight-just uses a helical diff to drive the front axles and a lockup clutch in the converter. Uses a band for second gear. Judging by what you just posted, the coolant likely delaminated the intermediate band, or there is a governor issue. Any auto trans will not last very long when you discover the strawberry milkshake. Even if you fix the problem that initially caused it. Get the unit overhauled, or get a clean cutout. I wouldn't hesitate to install one of these used, I would just check the diff bearings and axis pin. Otherwise they are actually pretty durable little units...
MB
Re: Daughters 01 neon not shifting like it should? [Re: HPMike] #972163
04/13/11 04:25 PM
04/13/11 04:25 PM
9
On a road near you
On a road near you
9
This car has ran great with no issues till now. It dosnt slip, just wont shift out of first or it will but it takes its own time to do it.
