Gear Vendor install-E Body #972087
04/12/11 04:48 PM
04/12/11 04:48 PM
lancaster,california
johnnycuda Offline OP
Hey,just wondering if anyone out there has performed a install on a Gear Vendor in a E body,,if so,how much modification was needed to clear the tunnel?,Presently my 'Cuda has a 499/727 combo with a 8 3/4 rear.
Thanks in advance for any info offered or supplied.If you happened to have taken pics,please post them here or email them if possible,,thanks again!!
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: Gear Vendor install-E Body [Re: johnnycuda] #972088
04/12/11 06:34 PM
04/12/11 06:34 PM
BC
70RT27N Offline
70RT27N  Offline
BC
This isn't an E body, but well worth the read...
https://board.moparts.org/ubbthreads/show...part=1&vc=1
Re: Gear Vendor install-E Body [Re: 70RT27N] #972089
04/12/11 08:09 PM
04/12/11 08:09 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
There is also the shorty version which I have been considering myself...I have an A500 in my one hotrod and the OD is just awesome...
http://smrtrans.tripod.com/smrtransmissionsintro/id32.html
Re: Gear Vendor install-E Body [Re: johnnycuda] #972090
04/13/11 12:08 AM
04/13/11 12:08 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Ask them yourself in person at Spring Fling this weekend. They will have a booth at the show.
Re: Gear Vendor install-E Body [Re: johnnycuda] #972091
04/13/11 06:34 AM
04/13/11 06:34 AM
Northern Va
Mopar73340 Offline
Mopar73340  Offline
Northern Va
I installed one in my E-Body this time last year. Pretty straight forward instructons and easy job. There is a small amount of tunnel massaging needed around the rear of the unit but nothing big. I mounted the controller under the dash. You will also need to have your driveshaft shortened or do like I did and have a spare shortened so you can go back if necessary. I am very happy with it with about 1K miles so far.
Re: Gear Vendor install-E Body [Re: johnnycuda] #972092
04/13/11 02:10 PM
04/13/11 02:10 PM
NASHVILLE
MAVERICKSHEMI Offline
NASHVILLE
Johnny, Sent you a Email and it kicked Back.
email me about G/V.
maverick3@charter.net
Re: Gear Vendor install-E Body [Re: Mopar73340] #972093
04/13/11 04:13 PM
04/13/11 04:13 PM
Hey guys,thanks for the info,I've installed this before in my Dodge truck,pretty simple install,,it's the amount of massaging required in my '70 was my concern.I talked to G/V a while back,was told I had to cut out a piece of the floor,and make a patch to clear tunnel,,I planned on having a spare driveshaft shortened in case a problem arises at some point.
Hey,Maverick,my email went done yesterday,supposed to up again in a day or so,,sorry.
Re: Gear Vendor install-E Body [Re: 70RT27N] #972094
04/13/11 04:18 PM
04/13/11 04:18 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
I've put some good miles on the GV since I made this thread and it's performed flawlessly. Can't image that an e-body would need that much massaging. Remember, you can also lower the unit away from the floorpan with a slight modification to the tranny crossmember...
Troy
Houston Mopar Connection Club
Re: Gear Vendor install-E Body [Re: hemi68charger] #972095
04/13/11 11:01 PM
04/13/11 11:01 PM
Bucks County, PA
500Stroker Offline
500Stroker  Offline
Bucks County, PA
Put one in my 73 Challenger 6 years ago. Minor massaging with an air hammer on the passenger side of the hump.
