largest tire on the front of a 68-70 B-Body #972047
04/12/11 03:12 PM
04/12/11 03:12 PM
Regina, SK, Canada
charger Offline OP
charger  Offline OP
Regina, SK, Canada
What's the largest tire you've run or seen run without rubbing..
I have a set of 255/60-15's I wanted to put on the front temporarily while my 235/60-15's get new rims on them. Any trouble?
Re: largest tire on the front of a 68-70 B-Body [Re: charger] #972048
04/12/11 03:28 PM
04/12/11 03:28 PM
La Grange, Ky
70rrclone Offline
70rrclone  Offline
La Grange, Ky
i have 245/60's on the fron of my 70 Sat with no issues. when these wear out i am going to the 255/60. there is plenty of room.
Shane
Re: largest tire on the front of a 68-70 B-Body [Re: 70rrclone] #972049
04/12/11 03:31 PM
04/12/11 03:31 PM
Regina, SK, Canada
charger Offline OP
charger  Offline OP
Regina, SK, Canada
oh yeah, these are for a '68 Satellite
Re: largest tire on the front of a 68-70 B-Body [Re: charger] #972050
04/12/11 04:19 PM
04/12/11 04:19 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
How about a 275-40-18?
Re: largest tire on the front of a 68-70 B-Body [Re: charger] #972051
04/12/11 04:23 PM
04/12/11 04:23 PM
Detroit area
6PAX Offline
6PAX  Offline
Detroit area
I have 255-60-15 tires on 15x7 rallys on the front of my 70 GTX and I don't have any rubbing issues.
Re: largest tire on the front of a 68-70 B-Body [Re: 6PAX] #972052
04/12/11 09:05 PM
04/12/11 09:05 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I have 265/50R15s on 15x8 4.5BS (Ramcharger) steelies on mine. And it's lowered a bit. Never a rub.
Re: largest tire on the front of a 68-70 B-Body [Re: topside] #972053
04/12/11 10:59 PM
04/12/11 10:59 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
on my charger, I used to run 255/50/16 and now I run 255/45/17. no issues.
Re: largest tire on the front of a 68-70 B-Body [Re: Pool Fixer] #972054
04/13/11 12:20 AM
04/13/11 12:20 AM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
I'd think 68-70 Chargers will have different about of room in different places than 68-70 Satelites and Coronets.
Re: largest tire on the front of a 68-70 B-Body [Re: charger] #972055
04/13/11 02:52 AM
04/13/11 02:52 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
255x60x15" on the '69 R/T convertible. Every once in awhile they lightly catch the top of the wheel opening molding, but my T-bars are fairly soft.
Re: largest tire on the front of a 68-70 B-Body [Re: 451Mopar] #972056
04/13/11 03:39 AM
04/13/11 03:39 AM
So Cal
So Cal
What was the rims size and the backspacing.
Need to know this for every application.
Re: largest tire on the front of a 68-70 B-Body [Re: autoxcuda] #972057
04/13/11 06:06 PM
04/13/11 06:06 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
7" rims, and (I think) 3.5" backspacing.
Re: largest tire on the front of a 68-70 B-Body [Re: charger] #972058
04/13/11 07:06 PM
04/13/11 07:06 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
All you need to do is check the diameter of a G70-15 tire that came on the '69 A12's because they had to add a .250" shim under the bump stop to prevent it hitting "something" by the engineering drawings/specs.........that doesn't answer how wide the tire can be (if that's what you're asking) but as far as "what's the tallest tire you can put on a '68-'70 B-body to engineering concerns then a G70-15 or maybe a 15" 78-series tire should give you a ballpark answer.
MikeR
Re: largest tire on the front of a 68-70 B-Body [Re: Pool Fixer] #972059
04/13/11 09:34 PM
04/13/11 09:34 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
the 16x8" wheels had a 4.5" backspace, the 17x8 wheels also have 4.5"
Re: largest tire on the front of a 68-70 B-Body [Re: Kern Dog] #972060
04/13/11 09:37 PM
04/13/11 09:37 PM
QLD Australia
Keith Black® Offline
QLD Australia
me too
Darren Beale
Keith Black Racing Engines®
Re: largest tire on the front of a 68-70 B-Body [Re: Keith Black®] #972061
04/14/11 06:36 AM
04/14/11 06:36 AM
Australia
charger RTSE Offline
Australia
245 60 15 on front of 70 charger 15 by 8 inch rims
Re: largest tire on the front of a 68-70 B-Body [Re: charger RTSE] #972062
04/14/11 09:30 AM
04/14/11 09:30 AM
Regina, SK, Canada
charger Offline OP
charger  Offline OP
Regina, SK, Canada
Update: the 255/50-15 fit fine on the front and looks fine with 295/50-15 on the back
Re: largest tire on the front of a 68-70 B-Body [Re: charger] #972063
04/14/11 11:09 PM
04/14/11 11:09 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Pictures please! Will need new front wheels soon so trying to figure out what looks good. I have the 15x10 on the back w/ 295-50's.
Re: largest tire on the front of a 68-70 B-Body [Re: 68KillerBee] #972064
04/15/11 12:12 AM
04/15/11 12:12 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Here's my RR with the 265/50R15 fronts, 295/50R15 rears, all on same 15x8 Ramcharger steelies, 4.5 BS.
If I had it to do over again, I'd go with 60 series for more sidewall height; the 50s look a bit slim in side profile to me. Also, the 15x8s are a bit narrow for a 295 tire.
He's a bit of a workout when parallel parking, with that big-valve-cover lump in the nose and manual steering, if that matters, but I do like the way they fill up the width of the wheelwells.
Re: largest tire on the front of a 68-70 B-Body [Re: topside] #972065
04/15/11 01:16 AM
04/15/11 01:16 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Went to the garage and took this photo of the passenger front tire at full right lock.
This is the 255x60x15" tires:
Re: largest tire on the front of a 68-70 B-Body [Re: 451Mopar] #972066
04/15/11 01:24 AM
04/15/11 01:24 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
You can see where the tire has caught the wheel opening molding, this usually only happens at high speed cornering. Topside's car looks like it sits higher than my car or 68killerbees car? I'd like to see the clearance on frankendusters Charger with the wheels at full lock? It looks like those rims may have more back space?
Here is a close up from my avatar pic:
