Re: largest tire on the front of a 68-70 B-Body
[Re: 451Mopar]
#972056
04/13/11 03:39 AM
04/13/11 03:39 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
255x60x15" on the '69 R/T convertible. Every once in awhile they lightly catch the top of the wheel opening molding, but my T-bars are fairly soft.
What was the rims size and the backspacing.
Need to know this for every application.
[Re: Pool Fixer]
#972059
04/13/11 09:34 PM
04/13/11 09:34 PM
Posts: 3,001 Coram, NY
Pool Fixer
Coram, NY
on my charger, I used to run 255/50/16 and now I run 255/45/17. no issues.
the 16x8" wheels had a 4.5" backspace, the 17x8 wheels also have 4.5"
[Re: charger]
#972063
04/14/11 11:09 PM
04/14/11 11:09 PM
Posts: 6,445 Missouri
68KillerBee
Missouri
Update: the 255/50-15 fit fine on the front and looks fine with 295/50-15 on the back
Pictures please! Will need new front wheels soon so trying to figure out what looks good. I have the 15x10 on the back w/ 295-50's.
[Re: 68KillerBee]
#972064
04/15/11 12:12 AM
04/15/11 12:12 AM
Posts: 20,848 A collage of whims
topside
A collage of whims
Here's my RR with the 265/50R15 fronts, 295/50R15 rears, all on same 15x8 Ramcharger steelies, 4.5 BS. If I had it to do over again, I'd go with 60 series for more sidewall height; the 50s look a bit slim in side profile to me. Also, the 15x8s are a bit narrow for a 295 tire. He's a bit of a workout when parallel parking, with that big-valve-cover lump in the nose and manual steering, if that matters, but I do like the way they fill up the width of the wheelwells.
[Re: 451Mopar]
#972066
04/15/11 01:24 AM
04/15/11 01:24 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
You can see where the tire has caught the wheel opening molding, this usually only happens at high speed cornering. Topside's car looks like it sits higher than my car or 68killerbees car? I'd like to see the clearance on frankendusters Charger with the wheels at full lock? It looks like those rims may have more back space? Here is a close up from my avatar pic:
[Re: charger]
#972069
04/15/11 07:01 AM
04/15/11 07:01 AM
Posts: 10,146 A Red State
SNK-EYZ
A Red State
255/60R15's will fit on the front. The wheel offset is the main concern. If you use 15x7 with a 4.25 rear spacing you should be fine. That what's on the front of this GTX I used to own. It had 275/60r15'son the rear.
[Re: SNK-EYZ]
#972070
04/16/11 02:44 AM
04/16/11 02:44 AM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
Sorry to hijack the post. A guy is coming over this weekend to perhaps buy a set of 15x8 AR200S's with 245/50s on them. The BS is 3-3/4". His car is a '68 GTX. Is he gonna have a problem? The car is same as OP's Q, so I figured it was a legit question...
