Rear end seal?? #971878
04/12/11 11:43 AM
04/12/11 11:43 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Is the pinion seal the same for a 742, 741, and 489?
I need to find a pinion seal for a 742, but kragen wanted $45 for one! Anyone have a more affordable source?
Can anyone give me a part #?
Re: Rear end seal?? [Re: mopowers] #971879
04/12/11 11:46 AM
04/12/11 11:46 AM
Slidell, La.
doctor_mopar Offline
Slidell, La.
The seals are different for each. I JUST ORDERED A SEAL FOR A 742 FROM ROCK AUTO online. It was a Timken , and was under $20. part number 7216
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: Rear end seal?? [Re: doctor_mopar] #971880
04/12/11 11:53 AM
04/12/11 11:53 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Thanks man! Are you sure about the part #? I couldn't get anything to pop up when I searched it
Re: Rear end seal?? [Re: mopowers] #971881
04/12/11 11:59 AM
04/12/11 11:59 AM
Slidell, La.
Slidell, La.
I made a mistake at first ( a little dislectic I guess) The number is 7216
Re: Rear end seal?? [Re: doctor_mopar] #971882
04/12/11 12:01 PM
04/12/11 12:01 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Thanks Doc. It looks like they've got em for $19. Thanks!
